Need Some Help PLz
  • 502M3JOHN
    • Dec 2010
    • 75
    Need Some Help PLz
    k well im new here to R3vlimited and i just got done with my s50 swap in my 87 325is but anyways just put my front e36 m3 swap on and my tires are rubbering the crap out of my fenders and i know you need 96+ control arms but i used 95 to see what would happen lol my mistake but, is there any other way to center my wheels away from the fender without buying 96+ controls for 200 a pop? thanks john
  • e-durty
    • Mar 2008
    • 110
    roll your fenders
    • Dj Buttchug
      • Jun 2010
      • 7678
      where is it rubbing? you probably have a major caster issue
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • 502M3JOHN
        • Dec 2010
        • 75
        its rubbing toward the driver door its like if you were looking at the car from the drivers side its against the right of the fender, ill try to roll it tomorrow see what happens this sucks!
        • Aptyp
          • 6584
          what offset wheels are you running? Usually you'd be rubbing on the inside in turns.
          You can move strut mounts forward
          • 502M3JOHN
            • Dec 2010
            • 75
            et 38, i tried 16's first then 17's and 17's looked like the would work if only i had like a thin'er tire than a 235 and how do u move the struts forward? thanks
