e36m front/ti rear Brake Bias
  • blueapplesoda
    • Dec 2005
    • 1904
    When I was running w/o abs, I could easily lock up my fronts, and I have done it on numerous occasions when driving on the street (panic stops + street tires), and even a few times on the track. Not intentionally of course, as I don't like flat spotting tires. I've bled the system a trillion times thinking the rear calipers were frozen or something, all to no avail.
    I've put the ABS back in just as a safety measure. Obviously, the bias is off. I am running the stock booster with the stock e30 master.
    I thought about running a set of pads with more bite in the rear, but I feel like its kind of a band aid to the problem. Is there another master that will get more pressure to the rear? Or maybe some other sort of trick to equalize brake force?
    Derek
  • BenM
    • 2184
    I have been fighting this problem for a while too and have looked into a few different ways to deal with it. I am running HT10s up front & DTC60s in the rear, but it would be better to utilize another way. As far as I can tell there are a few solutions:
    1. (the best IMO, but most expensive) Z3 M Coupe/Roadster Rear Trailing Arms & Brakes.
    2. Remove the proportioning valve below the booster on the frame rail & install an adjustable wilwood or summit valve. Use different rear pads if bias still exists.
    3. Bug Brake Kit for 318ti (Massive comes to mind). This is also expensive.
    Not a whole lot of options, but these are just a few that come to mind. HTH.
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • BenM
      • 2184
      Also, I would switch to a 25mm Master Cylinder as it will help the pedal feel tremendously (stock is 22mm).
      2012 F350 6.7PSD
      • MaksV
        • 1042
        I would say use the distribution valve and call it a day.
        CHEAP REBUILT INJECTORS
        Need Quality Brakes? BimmerBrakes has it!
        For anything Else go with BluntTech!
        • etxxz
          • Feb 2006
          • 2085
          ^^ +1
          So, its been criticized a few times. idk why. I simply put a wilwood brake bias on the front line and was done with it. Even with the rear limiter off/bypassed the front needs to be pressured down. Works beautiful now i have yet to experience brake fade at the track with these brakes and track compound. Its awesome having your rear brakes work for something more than aesthetics ; | and they aint even that good looking
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • blueapplesoda
            • Dec 2005
            • 1904
            lol I can see why you've been criticized. It's generally looked down upon to bias the front channels, but that is exactly what our 5-lug swaps need.
            Ive got the 25mm master, just gotta put it in.
            • IanS_in_Oz
              • Jan 2010
              • 75
              Every resource I can find on the web says you should never put the valve on the front.
              I am currently working on fitting some E46 330ci rear rotors and E36 328i calipers. (I have these parts lying around)
              I'm running a Mercedes 230E master cylinder
              BumbleE30 M52 2.8i
              • diegom6
                • 4447
                Derek
                Same issue here. My ABS isn't working due a bad rear sensor (replacing it soon).
                I wonder if the rear brakes or the whole brakes from a wrecked e46 M3 that I spoted could work in nour 5 lug e30 cars? Anyone ever tried it?
                Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                • JTapper
                  • Sep 2009
                  • 847
                  25mm master will make all your dreams come true. Seriously.
                  I ordered mine from Bimmerworld.
                  Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
                  • diegom6
                    • 4447
                    I have it already long tiem ago.:p But still the problem persist.
