E36 m3 axles with e36 ti trailing arms?
  • WheelE30
    • Apr 2011
    • 55
    Hey guys in the middle of my swap and wondering if I can run e30 axles or e36 m3 axles with the ti trailing arms I have Or do I need ti axles thanks?!
    • 37833
    You can run the stock E30 axles but you will need to remove or space out the ABS sensor.
    The E30 axles are definitely an upgrade over the tiny 318ti axles.
    Grover Beach, California
    BimmerHeads.com
    • Aptyp
      • 6584
      r3v needs a "like" button so I can like Matt's answer to indorse it.
        • 37833
        Haha!
        BimmerHeads.com
        • quakerE30
          • Jul 2011
          • 50
          if 318Ti bearings and hubs fit inside the stock e30 trailing arms, would the e36 m3 axles also fit?
          LEVINE AUTOMOTIVE
          • samiam3356
            • Jul 2009
            • 1901
            I doubt the diameter of the m3 axles is any where near the ti axles. It has been said the TI bearings are not as robust as the e30 ones so this would lead me to believe....NO!
            Edit:
            I heard this guy knows his shit
            Originally posted by Roysneon
            $5 shipped?
            Originally posted by MarkD
            You are a strange dude, I'n not answering any more posts from you.
            • IrocE30
              • Nov 2011
              • 104
              Asked this same question and had a set of e36 m3 axles laying around. they do not fit not only are the cv to big to fit in the hub, but the stub shaft is big diameter and higher spline count. How ever i do beleive that e36 non m3 axles will fit.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Can an e36 m3 hub be installed into a e36 318ti TA? would that allow e36 m3 rear brake install?
                  • 37833
                  No sir.
                  BimmerHeads.com
                  • McGyver
                    • 4636
                    well then would regular e36 hubs fit in the ti TA? this would allow for a thicker axle and (i assume) larger rear brakes than the ti stuff.
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Thanks Matt.
