hello R3V,
i have been reading and posting and trying to gather all the info i can, but now i have decided the 5lug rout i would like to go. i want to run the z3m rear brakes but have heard if you use the subframe and all it is in fact wider than the non m e30 and will have everything poke out and you have to go with a odd offset wheel. is this true? if so what would i have to do to utalize the z3m brakes on either the 318ti rear set up or standard z3.
thank you guys in advance for the help
