4 to 5 lug.
  • 1991 318is
    • Dec 2005
    • 786
    4 to 5 lug.
    Has anyone had a failure with 4 lug hubs? It seems that there are a lot of wheels and big brake kits available for the original 4 lug hubs. Is there a compelling reason for going to 5 lug hubs or a limitation that cannot be overcome by any other means? As a relative newbie I am just curious. Also, what is a reasonable cost for the conversion?
  • Brew
    • 3060
    Regarding the e30m3 front suspension w/ e36 m3 brakes, the big advantage is original BMW brakes with cheap replacement parts and a ton of aftermarket pad choices. You also get a lot more wheel choices, especially in wider sizes.
    '91 318is
    • rede30
      • 4697
      i plan to do it for the oem parts, brakes and wheels.
      • Jordan
        • 12913
        The 5lug conversion I did is the best bang for the buck with all OEM parts. Hard to beat what I'm running while staying within those guidelines.
        https://mtechniqueabs.com/
        • StereoInstaller1
          GAS
          • 22679
          Aren't the 5 lug hubs much stronger too?
          I won't be doing it ever, I really like my wheels. Plus, I drive slow.
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • Jordan
            • 12913
            The wheel bearings are significantly larger, and certainly more rebust.
            I just changed one of my e30 M3 front wheel bearings this week (went bad) and then compared it to a 4lug e30 one. No comparison. Both were SKF and the M3 one was much higher quality for sure.
            • Dave
              E30 RAT
              • 11675
              I have heard that some people who track e30s regularly replace front wheel bearings more often. There was an e30 in Roundel a while back that the owner swppped over to m3 5-lugs in part beacuse he and his wife were going through a lot of wheel bearings from track days.
              What jordan says tells the story - size does matter in some things.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Jordan
                • 12913
                Also, I forget the exact number... but the e30 M3 wheel bearing uses the same size ball bearings as the normal e30 one. There are just more of them. I think it was 8 more, or it may have been 12.
                • 1991 318is
                  • Dec 2005
                  • 786
                  Bearings?
                  Can you put the M3 bearings in a regular 4 lug hub?
                  • diegom6
                    • 4447
                    how much costed you all the parts that came from the junkyard car or whatever pieces you used from any car/place? except the newstuff like could be rotors/pads/brake fluid and such.... just wondering how much you spent just in that.
                    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                    • Jordan
                      • 12913
                      Less then $1000.
                      • diegom6
                        • 4447
                        Less then $1000.
                        then I think I got almost the whole 318ti compact suspesion kinda cheap. Do you know if the front part will work also, I mean it's the same hub/shock/strut size-diameter as the regular e36? or even the E36 M3?
                        I'm getting coilover as well.
                        Now I think I will lose my Koni adjustable front shocks since are inserts and the e36 and 318ti front shocks are one piece and not a insert like the e30 regular....:(
                        • Jordan
                          • 12913
                          Do not use e36 front suspension parts. Garbage. Gone over this WAY TOO MANY TIMES.
                          Do it right or not at all.
                          • diegom6
                            • 4447
                            Yeah, noticed a couple of times you mentioned not use front e36 parts, but never knew what do you used instead or maybe I forogot?
                            • gazellebeigem3
                              • Jun 2005
                              • 3712
                              e30 m3 front struts!
