5 lug convesion question
  • salty
    • Apr 2013
    • 29
    hey all i just registered in the forums
    been watching for almost a year now a lot of thing was learned through this forum
    need some help
    i swapped my E30 to 5 lug using :
    E36 non M control arms
    E36 non M hubs breaks spindles/steering knuckles
    E36 M 97 top mounts fliped ( left to right and right to left )
    E36 M conrtol arm offset bushings
    race land coilovers
    BBS RS 004 16x8
    my problem is that the wheels are not in the center they are to the back :(
    i have read that i have to use E36 M 96+ control arms and spindles
    my question is do i have to change both control arms and spinldes or one of them will do the job ??
    and if i used the E36 M 96+ spindles wich i found on bimmerworld now can i instal the non M bearing hubs disks brakes and calipers ??
    because i already have those and i am on a budget other wise i love M goodies :grin:
    will uploud pics soon
    help !
    96 E36 2dr 325is SC - Rip
    89 E30 2dr Mtech M50b25 SC - Rip (wasn't driving)
    90 E30 4dr Mtech m52b28 - parted out
    91 E30 2dr Mtech m20b25 - sold
    90 E30 4dr Mtech m50b25+ - current
    94 E36 2dr 318is - sold
    92 E36 2dr 325i 1jz-gte - Drift missile
    88 E30 4dr 320i - current Daily
    instagram @qammazy :nice:
  • wazzu70
    • Jan 2005
    • 1143
    You can use non-m spindles but need the 96+ M control arms
    -Nick
    M42 on VEMS
    • salty
      • Apr 2013
      • 29
      great thanks :D but would the non M brakes hubs ect fit the M 96+ spindles ??
        • 37833
        Yes, to center the wheel you need the 96+ M3 spindles and arms along with the offset CABs.
        How did you install E36 strut mounts? Drill new strut tower holes?
        You can run the non-M brakes on the M spindles but it's not ideal. You'll need to make a spacer for the caliper bracket to get it to center over the rotor.
        Grover Beach, California
        BimmerHeads.com
        • salty
          • Apr 2013
          • 29
          here i go with half good pictures & car is very dirty :D
          before installing the E36 M +96 top mounts this is the driver side as you can see
          [IMG][/IMG]
          after installing the E36 M +96 top mounts (flipped) with coil overs i kept one hole untouched which is the far to the right and made the close hole a bit bigger and drilled a new hole for the left side one
          [IMG][/IMG]
          my problem and rolled the fender because of 55 tires :(
          [IMG][/IMG]
          camber eat tire :D
          [IMG][/IMG]
          note: the E36 M 96+ top mounts cant be installed with original springs as shown because of the spring diameter are too large and will hit the fire wall
          • salty
            • Apr 2013
            • 29
            great info i just posted pics answering your question
            for now i will look for a complete M assembly but its very very hard to find if i couldn't find i will do the non M brakes and spacers on the M spindle
            beside the caliper would the non M bearing disk hub ect.. bolt on the 96+ M spindle ?
            • wazzu70
              • Jan 2005
              • 1143
              Yes, the hub is the same part for M and non-M applications.
              -Nick
              M42 on VEMS
              • salty
                • Apr 2013
                • 29
                thats very good news thnx
                sense i have every thing installed now new pads disks ect
                if i got the M spindle and M calipers the non M brake pads , disks would fit on them ?
                • rev3030
                  • Apr 2013
                  • 58
                  those wheels need just a little bit of tlc
                  • salty
                    • Apr 2013
                    • 29
                    i know man i just didnt have the time for it :D
                    • salty
                      • Apr 2013
                      • 29
                      am trina locate the 97 M3 parts no luck until now
                      any guidance ??!
                      ebay shit is scary they write it fits 97 M3 but (fits) doesn't mean it is an M3 97 part
                      looking for a complete M3 97 front assembly or at least arms or spindle with brakes
                      with reasonable price
                      help !
                        • 37833
                        I would recommend checking on Bimmerforums. People part out E36 M3s there all the time.
                        BimmerHeads.com
                        • rkettner
                          • Jun 2007
                          • 367
                          the way you've flipped and located the top mounts is going to make it twitchy. I'd switch back to regular e30 tops or atleast swap sides of the car that they appear to be installed on.
                          • salty
                            • Apr 2013
                            • 29
                            thanks guys :)
