E28 535i Hub assembly swap to get 5 stud
  • Massive Lee
    • Sep 2006
    • 6785
    #91
    Not selling them. Just made a set many, many years ago. Keep it simple and it'll work forever. Or spend big $ on an e30 M3 suspension.
    massivebrakes.com
    • wazzu70
      • Jan 2005
      • 1143
      #92
      People have sleeved the e30 4lug struts forever. What I dont know is if they replace the dust cap with a larger ring to support the inner bearing race half? OD on the bearing race support is 43mm. Inner diameter on e30 bearings is 30mm. Inner diameter on M3/E28 bearings is 36mm. The radius on the inner bearing race is 2.5mm.
      If you add that up you realise you only have 1mm on each side of the bearing supporting it from pushing in toward the strut! Not enough to make me comfortable!
      Just curious how people deal with this or if they just dont care.
      Any pictures of the setup you did Lee?
      -Nick
      M42 on VEMS
      • Massive Lee
        • Sep 2006
        • 6785
        #93
        Even if you had 0.5mm all around. that would be enough of a step to keep the bearing from "sliding" toward the strut. And it is a very precise job. Spindle will be frozen to shrink. Sleeve will be heated to expand. You'll need a good machinist. And nop. No picture.
        massivebrakes.com
        • Massive Lee
          • Sep 2006
          • 6785
          #94
          massivebrakes.com
          • Rocla
            • 922
            #95
            Google "bonje hylsa" for sleeve.
            EDIT: paradon me, bonje hylsa is for mounting e36 hub.
            Current:
            BMW 320i 2d 2.0 m20 -88
            BMW 325i Cabriolet 2.5 m50 -88
            BMW 316i touring 1.6 m40 -90
            BMW 320i 4d 2,2 m54 -01
            • wazzu70
              • Jan 2005
              • 1143
              #96
              Kiitos! Kippis! :)
              -Nick
              M42 on VEMS
              • wazzu70
                • Jan 2005
                • 1143
                #97
                Originally posted by Massive Lee
                Your buddy did a 4->5 lug hub conversion on a DTM strut housing? :(
                Or you are saying just go centerlock and be done with it! :)
                -Nick
                M42 on VEMS
                • Massive Lee
                  • Sep 2006
                  • 6785
                  #98
                  BUY a DTM racecar and be done with it... ;-)
                  massivebrakes.com
                  • wazzu70
                    • Jan 2005
                    • 1143
                    #99
                    Sounds good! I much prefer that option anyway :) Then I get the nice adjustable roll center rear suspension thrown in with it!
                    -Nick
                    M42 on VEMS
                    • wazzu70
                      • Jan 2005
                      • 1143
                      #100
                      onnistuuko jaon muutos vaihtatamalla pyörännavat esim e28sta? vai miten porukka on tehnyt muutoksen?
                      -Nick
                      M42 on VEMS
                      • rongineer13
                        • 72
                        #101
                        Not to highjack the thread or anything, but speaking of sleeving the spindle... http://www.r3vlimited.com/board/showthread.php?t=265863
                        They will be up for group buy in 2 weeks.
                        My 5 Lug Conversion Kit thread: http://www.r3vlimited.com/board/showthread.php?t=265863
                        5 Lug Conversion Kit Group Buy!! http://www.r3vlimited.com/board/showthread.php?t=281362
                        • enigmaticdream
                          • Jan 2010
                          • 572
                          #102
                          The three holes on the e28 strut don't align perfectly with the e30 m3 holes. One of the e28 holes is offset. Also e28 has M10 bolts vs M8 but that could be resolved with a little machining.
                          1986 911 Supercharged Frakenstrat/Stripped
                          1987 325is Delphin/Black (Olga)
                          1988 M3 Zinno/Natur (Elsa)
                          Manual or STFU
                          E30 Chapter of BMW Car Club of America
                          E30 Oktoberfest 2017
                          • brent5631
                            • Jun 2012
                            • 421
                            #103
                            I did the e28 bearings with a sleeved spindle. Have a thread just a few down from this one. Shows pictures of my sleeve and I did create a new step for the 5 series dust shield.
