Will 16x8" wheels fir correctly w/M3 suspension?
  • autoxguy305
    • Dec 2005
    • 36
    I'm about to purchase a set of 16x8 wheels that are et11. I was reading though a few posts and saw that you should have an ET of 30-40 with m3 suspension. I honestly don't know what will work as i have no experience with this suspension.
    I thought an et of 30-40 was only used on FWD cars.
  • Jordan
    • 12916
    Not with that offset NO.
    16x8 would fit with a ET25 offset. ET20 is very much right at the edge and you will likely need to run stretched tires.
    https://mtechniqueabs.com/
    • autoxguy305
      • Dec 2005
      • 36
      Thnaks Jordan :up:
      • Ray Smoodiver
        • Jun 2004
        • 8809
        Jordan, would it be possible to run style 5's your current 5 lug setup? mine is currently stock E30 m3 all round, but am looking to go bigger brakes like you have.
        Possible with spacers or no way in hell?
        • Axxe
          • Aug 2004
          • 3355
          Spacers would make it worse if anything. Style 5's are already low offset wheels. I doubt Jordan can fit Style 5's on his car, since he needs E36 offset wheels, which are a higher offset than the style 5's, or any E39 wheel.
          Keep it slideways!!
          • Jordan
            • 12916
            No, no way in hell.
            Low offset wheels will not work.
            • Jhonno
              • Nov 2004
              • 736
              im running et 20 16x7 BBS rims and they fit JUST with 205/50 tyres
              ///M Inside
              • Jordan
                • 12916
                Welcome to forever ago.
                Also this loser was banned, forever ago, right around the time this thread died.
                • Jhonno
                  • Nov 2004
                  • 736
                  quiet forum then eh? this thread was near the top didnt look @the date or user's status
                  still info for anyone searching
                  ///M Inside
                  • Jordan
                    • 12916
                    Proper 5lug swaps are expensive. e30 forum kiddies don't have money. duh.
                    • X2theZ3
                      • Mar 2004
                      • 932
                      style 5s came in e36 offset also. Sport option on the 328 i believe.
                      • 1990m3
                        • 1180
                        I bolted on the 17x8.5 et13 wheels from my m3 last weekend to my 318 w/e30 m3 suspension. No clearance problems at all, I could easily run that setup if I rolled the rear fender lip. I had lock to lock with no rubbing. 235/40/17 all around.
                        It looked funny with the wheels poking out of the fender by 1"...I know it's euro cool, but it was a little too much poke for my taste.
