Coilover / 5-lug Q *Rephrased*
  • cwatt
    • Oct 2012
    • 275
    *Completely Revised*
    Hello again,
    What I should have originally asked is this - I'm interested in going coilovers on an e30 and want to run a 5-lug set-up. What would be my best approach?
    Should I weld e30 coilovers on e30 m3 spindles? e30 coilovers on e36 spindles? e36 coilovers on e36 spindles?
    other info: I intend to do a e36 steering rack swap and custom brakes (most likely Willwood). My concerns lie in which steering knuckle, control arms, and offset.
    many thanks,
    - Colin
  • FLG
    • Sep 2011
    • 3165
    If you search you'll see its not that simple. They're was a guy selling conversions which did just that. Not something you can do yourself.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • IronFreak
      • Dec 2012
      • 3702
      And the conversion is crazy expensive.
      Instagram @rebellionforge
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        • IronFreak
          • Dec 2012
          • 3702
          What are you using the car for?
          Read this, many opinions in there: http://www.r3vlimited.com/board/showthread.php?t=304008
          • cwatt
            • Oct 2012
            • 275
            Wheels. It's all about wheels.
            I'm going to buy coilovers one way or another, so if I'm going to to spend the money I may as well open up my wheel options at the same time.
            • rkettner
              • Jun 2007
              • 367
              I'd suggest that there are more wheel options at 4x100
              • Northern
                I like cupcakes & sh!tboxes
                • 5234
                E30 m3 setup with gc coils, or e36m 5 lug with the gc bastard kit
                Originally posted by priapism
                Originally posted by shameson
                • Skon990
                  • Oct 2018
                  • 1
                  E30 coilovers
                  I'm currently fitting E46 coilovers to my E30. What's required for the swap is to machine the struts out of the hubs, and the coils lower part can be slid in and welded intheir place. If you search for #e46coiloversone30 on Instagram, there is a fella on there who's already done it with pictures.
                  • Zambuzan
                    • Nov 2017
                    • 434
                    What? So it's an e46 shock+spring & still e30 4-lug?? Or e30 shock+spring & e46 5-lug?? Doesn't seem like the best way to do it lol. e36 m3 swap is where it's at.
                    "Time doesn't heal anything... It just teaches us how to live with the pain." - My Cracked Dashboard
