Another 5lug option? | Now for the rear too!
  • rzerob
    • Jun 2013
    • 2315
    #151
    Thanks, like I wrote I am not good with offsets. I would need to run hub centric rings as well, how thick are hub centric rings? I was just about to pull the trigger on fill and drill, but then I saw this. And if it will work I would rather go this route.
    • jalopi
      • 2370
      #152
      hub centric rings don't effect total offset. they're 'pressed' into the wheel and are flush with the wheel's mounting surface.
      • Max399
        • Feb 2013
        • 991
        #153
        Update! Rear adapters available! All info can be found in the FS thread over here: http://www.r3vlimited.com/board/showthread.php?t=306268
        5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
        Leave feedback about my transactions!
