Another 5lug option? | Now for the rear too!
  • jalopi
    • 2370
    #106
    Just took a look through the other thread - those adapters are for e36m3 hubs, which aren't compatible with non-m hubs, right? If so... the two products aren't even comparable.
    • wazzu70
      • Jan 2005
      • 1143
      #107
      The E36 M3 hubs and E36 non-M hubs are the same.
      -Nick
      M42 on VEMS
      • jalopi
        • 2370
        #108
        Yep, my bad - I misread the part about the m3 brakes.
        • Max399
          • Feb 2013
          • 991
          #109
          Hubs will fit, its the caliper that will not :)
          5-lug Kit | E36 & E46 Hub & Brake Adaptor for E30!
          Leave feedback about my transactions!
          • e30m3s54turbo
            • Jun 2010
            • 3292
            #110
            Originally posted by wazzu70
            FWIW, there is clearly a demand for just the spacer sleeves. You and Ron (Im assuming thats his name from the username) should just list a price for the adaptors only if you havent already.
            Some people will buy yours, some people will buy the OPs. Everyone wins.
            BTW, these sleeves have been available for years in Europe (at least a decade) by various companies using this exact same design. Its nothing new or unique.
            • Max399
              • Feb 2013
              • 991
              #111
              Also, a reply on the Wilwood calipers sone of you asked.
              It would be posible to create brackets for them, but only if the shop would have the calipers physicaly.
              • Northern
                I like cupcakes & sh!tboxes
                • 5283
                #112
                Any particular reason you want to run wilwood superlites instead of dynapros? Theyre almost twice the price...
                Originally posted by priapism
                Originally posted by shameson
                • Max399
                  • Feb 2013
                  • 991
                  #113
                  If that question is to me then i have no idea, i just answered the question i was asked :)
                  • jalopi
                    • 2370
                    #114
                    Lol cuz I don't know shit about aftermarket calipers, good to know about the massive price difference though.
                    • yahh
                      • Aug 2012
                      • 800
                      #115
                      I'll buy a set of calipers and send them over of I get a free set. :)
                      Sent from my Nexus 5 using Tapatalk
                      s50 86 325e Project
                      S50 - BBS - Recaro - BC Coilovers - Morimoto H1 Retrofit
                      Feedback Thread
                      • Max399
                        • Feb 2013
                        • 991
                        #116
                        Id do that too :D
                        • jalopi
                          • 2370
                          #117
                          Hmm... so after crunching some numbers, it looks like if all you want is brake torque, go for the 330i calipers.... which is what I want. The piston surface area is somewhere around 4.3 sq.in. and wilwood's site doesn't list their calipers as much larger (enough to make a cost efficient decision. I guess the only thing they've got going for them is they don't float)
                          Just to double check, the e46 330i caliper brackets will bolt onto the supplied bracket adapters? If so, please PM me paypal instructions.
                          • yahh
                            • Aug 2012
                            • 800
                            #118
                            The only problem with the 330ci calipers will be considerably more brake fade and twisting compared to wilwood calipers that are designed for track use.
                            s50 86 325e Project
                            Feedback Thread
                            • Max399
                              • Feb 2013
                              • 991
                              #119
                              330 brakes do work, 100%.
                              • jalopi
                                • 2370
                                #120
                                Can't contest that, but my car is a drift/street/very-occasional-HPDE hybrid with manual, 100% stock brakes. All I really want is near-stock brake effort and stopping power, that's all.
                                Using the calculator at http://www.jakelatham.com/radical/in...culators.shtml I came up with the following (rough) figures:
                                Needed brake torque (based on 2700lbs, 50/50 weight distribution and a cg height of roughly 18"): 3262.5 lb/ft
                                All figures are with a 6:1 pedal ratio and 70lbs of brake pedal effort
                                E30 stock everything
                                F: 535.46, R: 329.81, Total: 865.27 (and yes, it feels like my brakes are way underpowered right now)
                                3/4" Master cylinder
                                F: 771, R: 474.9, Total: 1246
                                5/8" Master cylinder
                                F: 1110.3, R: 683.9, Total: 1794
                                E36 brakes, stock e30 master
                                F: 880.9, R: 414.42, Total: 1295
                                F: 1268.5, R: 596.76, Total: 1865
                                F: 1826.5, R: 859.34, Total: 2685.98
                                330i front brakes, E36 rear brakes, stock e30 master
                                F: 11434.7, R: 414.42, Total: 1558.13
                                F: 1646.95, R: 596.76, Total: 2243
                                F: 2371.6, R: 859.34, Total: 3230
                                They're significantly more powerful than the e30 brakes and were designed for a car that weighs roughly 600lbs or so more... hopefully they don't fade too bad under heavy use.
