Got mine today. They look great. Thanks Max!
Another 5lug option? | Now for the rear too!
Finally ordered mine! Can't waitComment
Anyone have installed pics yet? Quite curious about these.1991 325i - "Scambles" The Daily Driven lightly modded.
1988 Mazda RX-7 TII "Mako" The Free Dorito
bacon by Jared Laabs, on FlickrComment
They have been installed already, here's a link to one of the members build-threads: http://www.r3vlimited.com/board/show...=279110&page=9
Max.Comment
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
For anyone wanting to order - have one kit on my hands right now, can offer next day shipping :)
Max.Comment
Bump :)
For anyone still willing to order - still got one kit on my hands which i can ship next-day.
Also if someone did not notice - the For Sale thread has been updated with pics from a user who already installed these, he also made a nice step by step guide.
The F/S thread can be found right here: http://www.r3vlimited.com/board/showthread.php?t=306268
Max.Comment
Has anyone successfully used their ABS triggers with this kit yet. I'm trying to visualize the best way to re-mount them so they work.1991 325i - "Scambles" The Daily Driven lightly modded.
Currently i am not aware of anyone who did this. Also i think there should be a problem regarding the number of teeth the ABS ring has on e30 and on the later ones..Comment
I don't think that will matter, people using full e36 front setups just simply splice the e36 ABS sensors into the stock wiring. I doubt the number of teeth really matters. It's main function it to sense if a wheel has stopped rotating the way I understand it. The design isn't much different anyways.
I'm visualizing a bent sheet metal plate that just moves it to a location where it can set at the correct distance.1991 325i - "Scambles" The Daily Driven lightly modded.
Yes, i would image it as a spacer that moves a little inside and a little otside of the diameter.
I myself do not have ABS so cant test it :)Comment
Currently i'm dealing with possibly having to move, once i'm settled into a new house i'll be buying a kit. I'll figure something out for those still wanting ABS.1991 325i - "Scambles" The Daily Driven lightly modded.
Sup bros, here's my solution to the ABS 'problem'. No idea if it'll actually hold up... but if it doesn't oh well. There's also another potential solution, but I didn't really like it.
Here's a shot of the ABS ring-to-sensor set up before using the hub adapters:
Here's the potential solution I thought of: grind down the mounting surface for the ABS sensor. It's about the same thickness as the adapter and would push the sensor pickup out far enough. However, it's too irreversible for me, so I decided to go with option #2 first.
Here's a shot of the hub slapped on without modding anything. You can see how the ABS ring isn't close enough to the pickup.
My solution? Tap the edge of the ABS ring with a screwdriver, it'll pop loose. Position it in the correct area and then tack weld the bitch on.
Try to get it as straight as possible. No idea how long this'll last, but I just took a spin around my neighborhood and the ABS light didn't come on... so I guess it works? Whatever, I had nothing to lose. I'll post an update in a few months to let ya'll know if the welds hold or not.Comment
That's a good idea. I was thinking of doing your first idea but I'll have to see how we'll this holds upComment
