Sokay
GC sells a coilover kit that uses the e30 m3 "strut", but has an e36 mounts at the bottom to run e36 hubs versus the traditional e30 welded-in spindle.
HOWEVER: GC sells 2 kits. A e36 non-M and an e36 M3 version. I want to run 16" wheels, and I know that selection for e36 m3 5-lug is very limited as not very many 16" wheels are large enough inside the drop-rim to clear the larger M3 brakes.
I was thinking of ordering the non-M kit, however; I wanted to know cold hard facts about the non-M vs the m3 in terms of hub size, brake diameter, caliper clearence, etc.
So, my main questions are:
A) Would my brakes be smaller and clear most (if not all) 16" wheels if I ran e36 non-M hubs/brakes versus running e36 M3 hubs/brakes?
B) What would running e36 hubs do in terms of Offset? Does anyone have any specs on this when comparing the hubs to normal e30 specs? Are e36 non-m hubs smaller in offset than the e36 M3 stuff?
C) I know running traditional e36 struts messes with camber and castor, but with the GC setup being based of the e30 M3, Im assuming castor isn't affected. However, what would it do to the camber? Would running traditional e30 control arms would not do anything to the camber? Or would the hub geometry of the e36 throw things off slightly?
This would solve my front setup
My rear would be a fusion of e30 rear arms, and what I believe to be Z3 2.8 hubs/brakes as people say these are direct bolt on at the hub
I am not sure about the rear setup yet, but I am currently researching it
