Why cant we use E36M3 rears and e brake?
  • Kingb
    • 928
    Whats the deal with not being able to keep an e brake. I know the hub on the rotors are bigger. Has anyone made a backing plate so that you can use M3 rear brakes and keep the e brake?
    Originally posted by Nicademus
    My car beats off to that car. :bow:
  • Loupoz
    • Feb 2012
    • 166
    Its possible to make a ring and pres it into the brake "drum" and keep the E-brakes function.
    My 325I Mtech1 S54 Build
    • plain325
      • Mar 2004
      • 163
      I used 128i rotors and e34 540i calipers. The 128 rotors have a much deeper "hat" than the e36 m3.
      I had to make custom brackets for the calipers, and i spaced the backing plates out .25", but it gave me brakes almost as large as e36m3, and functioning e-brake.
      I have z3- 6 cly hubs, so if you are using 318ti hubs, you may not need to space the backing plate out.
      • Julien
        • 7471
        you can also get 300mm.de brackets to fit e36m3 calipers and z4 rotors
        Build Threads:
        • Todd Black 88
          • Oct 2007
          • 3449
          Rongineer makes brackets to fit e46 325 rotors and e39 528 calipers. Same ID hub so ebrake stays the same.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • e30m3s54turbo
            • Jun 2010
            • 3292
            On my Alpina B6 3.5 clone I am using e36 318ti trailing arms, z4 rear VENTED rotors (294x19mm), e36 m3 rear calipers and 300mm de 294-3 adapters.
            • Kingb
              • 928
              Does the parking brake with with the Z4 rotors?
              • e30m3s54turbo
                • Jun 2010
                • 3292
                Originally posted by Kingb
                Does the parking brake work with the Z4 rotors?
                Yes it does work.
                • Julien
                  • 7471
                  Nice! I want to do this mod next
                  Build Threads:
                  • Julien
                    • 7471
                    but is the offset suitable for 318ti hubs?
                    Build Threads:
