Good read.
Z4 rear hub
If you have bought items from me, please leave feedback below.
If you are a BUYER, Check My Feedback.:up:
http://www.r3vlimited.com/board/showthread.php?t=183860
Check out my Euro Build Thread
http://www.r3vlimited.com/board/showthread.php?t=215557
Originally posted by ngampleh View Postyou mean, bolt for brackets or adapters to calipers mount on trailing arm?-There are two undeniable truths in the tuning world; No matter how much money you put into that Honda, it's still a Honda, and no matter how little I put into My bimmer , It's still a bimmer.-
Originally posted by Jroc81 View PostI mean like, a bolt-on oem-parts solution. i.e. no custom parts, if that makes my question clearer
because there are many difference measurement :
1. caliper bolt spacing distance
2. trailing arm caliper mount to rotor distance
3. rotor diameter
unless, remove existing trailing arm caliper mount and make new caliper mount to fit[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
[ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
Transaction Feedback
Z4 rear hub
Originally posted by Jroc81 View Postbummer. z4 hubs are, for whatever reason, cheaper than non-m z3 hubs.
actually, I am not the OP... you may check on post #1
the reason for the z4 hub are...
1. I just continued the OP post, which inspired me to do 5lug..
2. Z4 is the closest offset thats match with e46 brake rotors (325/328/330)..
which I already have the e46 brake setup in that time
3. yes, its cheapest hub for rear 5 lug...
beside z4, you can use e30m3 rear hubs and buy the caliper adapters from 300mm.de
did you check #1 post from the OP?
its clearly explain there are rear 3 hubs type to do 5lug
- Z4 : +2.5mm
- e30m3 : +5mm
- e36 323ti : +16mm[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
Originally posted by ngampleh View Postactually, I am not the OP... you may check on post #1
- Z4 : +2.5mm
- e30m3 : +5mm
- e36 323ti : +16mmLast edited by Jroc81; 05-13-2016, 11:49 AM.-There are two undeniable truths in the tuning world; No matter how much money you put into that Honda, it's still a Honda, and no matter how little I put into My bimmer , It's still a bimmer.-
Would these adapters work on z3 rear trailing arms? Looking at putting some e46 330i brakes back there.My Garage
Feedback
Instagram: Stone.Hopkins
Z4 rear hub
Originally posted by stonea View PostWould these adapters work on z3 rear trailing arms? Looking at putting some e46 330i brakes back there.
yes, it will work on z3 trailing arms..
you may check on post #132
but you need to figure it out the parking brake..[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
Last edited by ngampleh; 05-17-2016, 02:36 AM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
4th batch production !!
>>> 4th batch ORDERED <<<
1. E30Logic - ordered
2.
3.
4.
5.
Next batch 5 sets production soon... (2-3 weeks)
price increased 135.00 + shipping
(shipping is not included now)
shipping to States are
10.00 - Priority Mail with tracking number (2-3 weeks)
20.00 - Express Mail with tracking number (5-6 days)Last edited by ngampleh; 06-02-2016, 09:11 PM.[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
Interested in a kit
Im very interested in a kit wondering if you got a set up for brackets in the front and rear or is this only for the rear?
I remember seeing the Nasieg 5-Lug Kit which was for m3 e46 or e36 brakes up front and e39 or e46 rears.
I want to run e46 m3 brakes up front and the rears you have on your kit are fine, just wondering if you got a complete kit for all corners? Thanks in advanced or if anyone else knows who sells a complete kit or a front kit by itself so I can purchase the rears from this kit?
Let me know bmw.m.racing@gmail.com Thanks!
Originally posted by Pancho22 View PostIm very interested in a kit wondering if you got a set up for brackets in the front and rear or is this only for the rear?
yes, its only rear adapter at moment..
I have designed the front bracket for e46m3, and I still waiting the US rotors from Germany.. they ship with sea-freight, will take long time..
I can get the ZHP rotors from Singapore for a week, but its pricey for me
unless you willing to use the prototype,
actually I dont want to sell some, without tried first at my e30..
and for the rear, why not using e46 330i?
its have same piston diameter, thicker rotors but 8mm smaller rotors diameter.
- e46m3 rotors is 328x20mm
- e46 330i rotors is 320x22mm
my rear adapter fits with z4 & e46 330i
I will send email to you for further discussion[ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
Thanks for quick reply
I understand you bro. No worries ill hold off on buying some, my build still needs alot of work everywhere else. I plan on getting a e46 m3 donor probably crashed so I figured if I could use the parts ill save money but i wouldnt have a problem using 330i rotors for the rear, but for the front I think the e46 m3 fronts would be ideal.
If your prototype works with the front e46 m3 once you get them ill buy a complete set from you it will be better for me too with lower shipping costs lol.
Thanks, looking forward to your email.
