Z4 rear hub
  • ngampleh
    • Jul 2012
    • 466
    #76
    Installed z4 hubs on stock rear trailing arm
    Front end
    Its all done...
    The OP question answered
    Thanks guys for sharing all things about hubs and rear brake
    [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
    • ngampleh
      • Jul 2012
      • 466
      #77
      Forgot rear end with 12mm spacers
      • cervantes559
        • Mar 2013
        • 75
        #78
        So what did you end up using for the rear z4 hubs with e30 ta what brake calipers and rotors?
        • ngampleh
          • Jul 2012
          • 466
          #79
          E46 325/328 calipers and rotors
          • ngampleh
            • Jul 2012
            • 466
            #80
            1000 miles tested and still running...
            pretty fun for 4 pot
            • Jim Lepage
              • Jul 2008
              • 1138
              #81
              I have a couple questions.
              Do you think these hubs can be safely redrilled 5x130 ? Do they have enough meat ?
              Do you think a standard E30 disc can go over them ?
              I'd like to run 5x130 hubs rear. I wanted custom hubs but since those can maybe be redrilled to 5x130 I'd only have to shim my calipers brackets 2.5mm each side and drill my discs too.
              E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
              • boy412
                • Apr 2013
                • 172
                #82
                Very nice. With all the different posts in this thread I've gotten a bit confused. Were you able to retain your e-brake with this setup and if so was it difficult to make work?
                1988 Alpineweiß 325iC
                2003 Audi A4 Avant 1.8T
                • ngampleh
                  • Jul 2012
                  • 466
                  #83
                  Think thats scary to redrilled to 5x130, it only 1mm meat (see left one with blue line)
                  I ever redrilled my stock hub 5x120, and its tested fine on track and 20k miles (see right one with red line)
                  There is still possible to make 5x130 on your stock hub..
                  Here the reference
                  Yes, stock e30 disc can run with small modification on the area that will attach to welded + redrilled hub
                  • ngampleh
                    • Jul 2012
                    • 466
                    #84
                    Sorry, if thread confused..
                    I retain my stock e30 e-brake
                    See this pic, old dirty e-brake stuff
                    • Jim Lepage
                      • Jul 2008
                      • 1138
                      #85
                      Here the reference
                      Thank you for your answer ! :up:
                      • ngampleh
                        • Jul 2012
                        • 466
                        #86
                        Glad to help and understand my english...
                        • Jim Lepage
                          • Jul 2008
                          • 1138
                          #87
                          Ahahah, english is not my native language too, don't worry, everything is fine. :D
                          • ngampleh
                            • Jul 2012
                            • 466
                            #88
                            What kind of wheels that made you want to modify the hub?
                            Pics pls
                            Why not 5x114.3 or below 120mm diameter?
                            • LJ851
                              • 7919
                              #89
                              5x130= porsche fitment
                              Lorin
                              The M30 is God's engine.
                              • Jim Lepage
                                • Jul 2008
                                • 1138
                                #90
                                Right !
                                I have 18mm adapters but I'd like thinner spacers to poke a little less.
