Z4 rear hub
  • ngampleh
    • Jul 2012
    • 466
    #91
    Originally posted by Jim Lepage
    Right !
    I have 18mm adapters but I'd like thinner spacers to poke a little less.
    what wheels spec that you will running on?
    If you want to use square tire same as mine,
    its gonna be maximum +12mm front and +14mm rear wider than stock
    and running 15x7 et20
    So if convert it to stock e30 offset, around 7" wide with et 6-8
    with stock rolled fender
    just my 2 cents
    [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
    [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
    Transaction Feedback
    • respected_beggar
      • May 2012
      • 69
      #92
      What rear rotor are you using? The link you have posted up isn't working.
      1988 325is imolarotII/ plastic bumper swap/ e36 m3-z3 2.8 5 lug swap/ e36 m3 bilsteins/ e36 m3 h&r race spring up front/ GC rear coilover / 21mm vert sway bar/ m3 offset bushing/ OEM bushings/ S3.73 rear end/ full black interior/ e46 sport seats/ BBS style 5
      Instagram - AnthonyVzz
      • ngampleh
        • Jul 2012
        • 466
        #93
        E46 325/328i rotors
        Which link? Is it on page 1?
        • Need4Speed1299
          • Oct 2007
          • 119
          #94
          What's the part number for the z4 hubs? There are a few types. 33416752381, 33412229120...
          • ngampleh
            • Jul 2012
            • 466
            #95
            33416752381
            • dsobering47
              • Oct 2007
              • 697
              #96
              Y'all know that e30m3 hubs can be pressed into any e30 trailing arm right? boom rear 5-lug. The problem is the brake setup
              • Need4Speed1299
                • Oct 2007
                • 119
                #97
                True. But would a z4 hub be cheaper and have a better offset?
                • kronus
                  • Apr 2008
                  • 13032
                  #98
                  any 84+ e30 trailing arm
                  the early trailing arm has a smaller wheel bearing, same size as the e36 318i.
                  cars beep boop
                  • CoreyZ
                    • 384
                    #99
                    Z4 hubs can be bought off salvage cars. I got a pair for $100. Find a dude selling parts off a Z4 on ebay - they're not gonna list the hubs, but most of the time they will say "Contact us if you need any other parts off the car"
                    • Need4Speed1299
                      • Oct 2007
                      • 119
                      #100
                      Excellent idea! Thank you.
                      • ngampleh
                        • Jul 2012
                        • 466
                        #101
                        Z4 rear hub
                        how to make sure the part number is correct? is it from year and model?
                        as I remember there no part number mark on hubs
                        • ngampleh
                          • Jul 2012
                          • 466
                          #102
                          No problem at all
                          Yes, its cheaper...
                          about the same offset, if you use e36 front hubs setup
                          • CoreyZ
                            • 384
                            #103
                            Yeah, year and model. It's easy here in the US since I believe all non-M Z4s (pre-current retractable hardtop generation) all have the same hubs IIRC. Your mileage may vary.
                            • knuklehead92
                              • Aug 2011
                              • 732
                              #104
                              is anybody making adapter brackets for this yet? I made my own but rather rather have something professionally done.
                              Trust me it stock :yawn:
                              • JOMARO
                                • Mar 2006
                                • 116
                                #105
                                I have found that some e90's share rhe same hub
