Fixing front camber (e36 m3 suspension)
  • funcrew
    • Jun 2007
    • 1223
    On my e36/M3 front setup, I ran OEM E30 strut mounts with Turner fixed camber plates. That yielded a little more than 2 degrees neg camber, just about right for mixed AutoX and street use.
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
      • 37829
      Originally posted by cokeisgood00
      What's the difference between e36 M arms and e36 non M arms? They look the same.
      They are not the same. The E36 M3 arms will put the wheel forward further.
      The parts list I recommended you install is the correct way to do the E36 based 5 lug.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • cokeisgood00
        • 152
        OK, so here's the parts list:
        GC? Camber plates, should I get the camber/caster ones? How are Ireland Eng. plates?
        e30 M3 offset control arm bushing
        What spring perches do I use up front? e36 or e30?
        Also, I have non-blown bilstein sports in the rear with the stock springs and blown sports up front with ebay springs.
        I had stock IS springs and sports on my e28 and loved the way it handled, but I think I'd like to get some H&R or Eibachs. Thoughts?
        Orr http://store.bimmerworld.com/bimmerw...kits-p879.aspx
        86 528e b25
        00 528i
        95 525iT
        88 325is m52
        86 325es m50
        • jalopi
          • 2370
          GC plates are the tits. Not that much more expensive than other plates but 10X as fancy/nice.
          yes to the bushing choice, either that or a compact loli style. THR is one version, the bimmerworld clone looks exactly the same but cheaper.
          at $400 for a set of control arms and bushings that better come with a BJ too
          • cokeisgood00
            • 152
            Select offset Powerflex, don't press them and no tie rods
            86 528e b25
            00 528i
            95 525iT
            88 325is m52
            86 325es m50
            • kwseattle
              • Nov 2013
              • 105
              What sort of camber are you guys achieving with stock e30 strut mounts? I guess it varies with ride height, but my strut mounts are redrilled e36 m3 ones and the bolts/bearings are pretty shot. I need to replace them with something but I can't drop the front of the car any more than it already is.
              Alpinweiss II 88 325is | M20 | 5 Lug Conversion
              Kyle
