Do these make the conversion in the rear easier?
  • gazellebeigem3
    • Jun 2005
    • 3712
    HAZZZZZZZZZZZZZZZZZZZZAAAAAAAAAAAA
  • gazellebeigem3
    • Jun 2005
    • 3712
    70 views and not one response?!?! fuck youse
    • EtaSport
      • 2853
      splined for e30 axles I assume, I always wondered why no one made or found a 5 lug hub for teh front and rear.
      Old and improved:
      • mcgrath
        • May 2004
        • 445
        looks like they are about $200 a side. any places to go to get them cheaper?
        • matt
          • 3732
          They're just e30 M3 rear hubs, right? Whats the big deal?
          Matt
          • bahnfire
            • 204
            yes, they are e30 m3 rear hubs. i was gloating because they are hard to find. I got a good deal and they made it sooo much easier to do the conversion!
            • matt
              • 3732
              I guess they let you use the stock e30 trailing arms instead of swapping the trailing arms for ti or z3 units, right? Cool. You still need all the M3 brake stuff, which will probably be just as hard to find as the hubs.
              Matt
              • bahnfire
                • 204
                Matt
                no actually, the rear calipers interchange with 7 series calipers (dont remember which model). Identical part numbers, you use your original brackets with them too. I picked up a set on ebay for 30 dollars. M3 rear wheel bearings and trailing arms are also identical to the non m. The only difference is the hub and brake rotor/caliper and backing plate. My five lug is done anywho!
                • matt
                  • 3732
                  e32 735i/iL according to the ETK. That's good to know, thanks.
                  Matt
                  • bahnfire
                    • 204
                    Matt
                    yup thats the one! unfortunatly, theres no interchange for the fronts.
                    • blunttech
                      • 12850
                      did the packages come with cnb's?
                      sales@blunttech.com
                      www.blunttech.com
                      Like us on Facebook
                      • bmws50b30
                        • Aug 2005
                        • 1151
                        hey steve i need some price quotes please. i want the cnb discount
                        1991 330is
                        • gazellebeigem3
                          • Jun 2005
                          • 3712
                          you know i think they may have... am i going to have to send you more checks????
                          • Beau B
                            • Mar 2004
                            • 734
                            You can use e28 front brakes, they bolt right on. I went with e28 m5 front brakes..
                            Beau
                            1988 BMW 325iS
                            • gazellebeigem3
                              • Jun 2005
                              • 3712
                              Beau
                              I ment in terms of e30 m3.. Obviously there are plenty of other options.
