Do these make the conversion in the rear easier?
  • rs4pro3
    • 5808
    Originally posted by bahnfire
    no actually, the rear calipers interchange with 7 series calipers (dont remember which model). Identical part numbers, you use your original brackets with them too. I picked up a set on ebay for 30 dollars. M3 rear wheel bearings and trailing arms are also identical to the non m. The only difference is the hub and brake rotor/caliper and backing plate. My five lug is done anywho!
    So the stock e30 carrier work just fine with the 735i/m3 calipers and give the proper caliper offset etc....
    85 325e 2.7 ITB'd stroker
    • Beau B
      • Mar 2004
      • 734
      Originally posted by gazellebeigem3
      I ment in terms of e30 m3.. Obviously there are plenty of other options.
      I am kind of confused as to what you are saying, but I am talking about in terms of e30 m3 front struts and hubs.. if you search s14.net you will see other guys running the same setup
      Beau
      1988 BMW 325iS
      • gazellebeigem3
        • Jun 2005
        • 3712
        Beau
        I mean that the p/ns for the 735 and m3 are identical, they are not just similar. Theres no such interchange for the fronts. Im not saying the e28 parts wont work, just that they arent m3 parts... which might matter to some people.
        worked fine on my ti trailing arms but i had to do some grinding to clear the rotor when i switched back to e30 arms with m3 hubs. I had about five pairs of rear brackets lying around and i may have grabbed the wrong ones.
        • rs4pro3
          • 5808
          ok cool, well I just purchased a set of the 735 calipers, so I'll see if my e30 brackets work, no I just have to order the rotors(if I can afford them as they are a dealer only item :roll: )
          • rs4pro3
            • 5808
            Well the stock e30 caliper carriers will not work with the m3/735i calipers. The carrier it self slides in fine and everything bolts up but the brake pads don't fit and can move around between the caliper and the carrier.
            • aeon
              • 36
              so, would these rear hubs, plus turner motorsports (really SK) e30m3 front hub assemblies, plus 2 sets of turners backing plates suffice for a 5 lug conversion?? all you'd need are the items mentioned above, plus e30m3 rotors/calipers to finish it all off right??
              if that's the case, that's easy as hell, and decently cheap for a stock alignment/offset retaining conversion :o
              • FredK
                • 14764
                No, the spindles are a different size in the front.
                M spindles are huge in comparison to the non-M spindles. The E30 M3 hubs are incompatible with E30 non-M hubs.
                • Mtriple
                  • 3139
                  Just to clarify, aside from the brakes, all I need to do is buy the rear hub assembly from the old man and I'm good right?
                  Originally posted by Simon S
                  • matt
                    • 3732
                    Yes. What he said is accurate.
                    • JDMpower
                      • Sep 2006
                      • 1771
                      What is the part # on those? :) I will have to keep my eye out for my own set. It looks like 33 41 2 225 510 but I think I am reading it wrong.
                      '89 "is" = M technic II build mode.
                      • aeon
                        • 36
                        2225510 are the last 7, which is all ya need boss ;)
                        • Rocla
                          • 922
                          Ok, I did not get it staright yet...
                          With m3 rear hub, dics and 700 series caliber, what carrier besides m3?
                          EDIT if I remeber correct, M3 has wider track, bu same trailing arm than other e30's, so new wheels must be with 5 greater et, right?
                          Current:
                          BMW 320i 2d 2.0 m20 -88
                          BMW 325i Cabriolet 2.5 m50 -88
                          BMW 316i touring 1.6 m40 -90
                          BMW 320i 4d 2,2 m54 -01
                          • matt
                            • 3732
                            Lower. M3 and 5 series use low offset wheels.
                            • Rocla
                              • 922
                              The main reason why I'm wondering this again is that I bought these wheels:
                              8,5*16" et 10 front and 9,5*16" et 14.
                              I'm quite sure that those will never be under my e30, but let play with the though, do you guys think that there is any chance to get those rolling under non M3 fenders?
                              And yes, they are 5 lug.
                              Current:
                              • nefarious7907
                                • Jan 2005
                                • 1170
                                subscribed :)
                                http://www.cardomain.com/ride/657387
