UUC E30-E36 FCAB bracket?
  • Zekerbox
    • 221
    http://store.uucmotorwerks.com/e30e3...ght-p1329.aspx
    Anyone have experience with these? UUC isn't very informative on their site. I'm assuming these allow you to run front Non-M e36 suspension/5lug setup without haveing alignment issues that Non-M suspension has? Insight/thoughts/experience?
  • mtech325
    • May 2008
    • 569
    I can't say I've seen these before, but they look to be for race applications. The picture (albeit not the best) shows no bushing. These look like they replace the control arm lolipop/bushing combo much like treehouse eyeball arms, but even the eyeball arms have a delrin insert. I'd give UUC a call and see what they have to say. Interesting find!
    • wingnut1961
      • May 2015
      • 9
      I talked to UUC and these are for correcting the geometry when using E36 LCA/LCABs on the E30. The lollipop bolts to the UUC adapter to shift the position of the control arm mount.
      • Artful Dodger
        • May 2008
        • 156
        These look to be just lollipop replacement. Similar to Treehouse Racing ones.
        I would be interested to see if they really make the hub fit the wheel well. It takes a little more movement than what you get with the treehouse or bimmerworld ones. This is why I made my own.
        • Artful Dodger
          • May 2008
          • 156
          Check out the pictures.
