E36 M3 Rear 5 Lug Method??
  • AirDoc
    • Sep 2006
    • 29
    Building an 88 325is Track Only car - no street usage - no need for e-brake.
    I can't seem to find from searching of an adaptor or prescription to merge the following:
    * 88 E30 Non-M Trailing Arms
    * E36 M3 Rear Calipers
    * E36 M3 Rotors
    * ?? Adaptor ??
    * ?? which hub to use - Z3/6, Z4 ??
    I happen to have E36 M3 Spindles/Brakes for the front and E36 M3 Rears, and this is common with my other track car - so that's my reason for this set-up desire.
    Any insight/input is greatly appreciated.
    Thanks in advance!!
    Nitin G. Shanbhag
    BMWCCA #101510
    76 2002, 88 M3 Racecar, 88 M3 2.5, 95 M3 Slicktop, 96 E36 Trackbeater , 97 M3/4 Slicktop
  • glucklich21
    • 1912
    I can give you some some insight from my swap. The guys over at 300mm.de offer an adapter that uses the e36 M3 rear caliper in combination with a Z4 rotor. With this setup you retain the proper braking ratio and gain a vented rotor.
    Uses:
    -Ti or E30 trailing arms
    -Ti Hub
    -Ti e-brake hardware (or Z4 if you replace the dust shield)
    -Z4 3.0si rotors
    -E36 M3 caliper
    More info can be found here: http://www.e30tech.com/forum/showpos...&postcount=182
    • AirDoc
      • Sep 2006
      • 29
      Thanks a bunch for your response, but it seems the adaptor is for Ti trailing arms - i.e. with the smaller bearing. I'm trying to retain usage of my E30 325 trailing arms and hopefully find a way to have the big rotors...although at this point I might compromise that point.....still hunting
      Nitin G. Shanbhag
      BMWCCA #101510
      • Wishno87
        • 6025
        Any more input on this? I like what I'm seeing.
        • dadsbmw
          • Oct 2014
          • 475
          wow, those 2 brackets and bolts are 178 euro!?
          2003 Z4 3.0 6-speed- Silver, 19's, daily driver
          1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
          1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
          • george graves
            • 20003
            Does anyone else make them?
            Originally posted by Matt-B
            • glucklich21
              • 1912
              I have a set that I'm inquiring about getting machined. I modified the design so that you don't have to run washers under the caliper to space it correctly. Hopefully should be priced around the $150 range.
              • AirDoc
                • Sep 2006
                • 29
                Price is quite reasonable.
                Is it going to work on E30 Non-M trailing arms?
                Will the config retain usage of E36 M3 Rear Rotor?
                thx,
                Nitin G. Shanbhag
                BMWCCA #101510
                • glucklich21
                  • 1912
                  thx,
                  Yup it's designed for non-M trailing arms (so 318ti/E30). It uses a Z4 rotor that's 294mm and vented. Works with the stock 318ti parking brake setup. I'll have two versions. One for use with the E36 M3 rear caliper and one for a 540i rear caliper.
                  • peterz
                    • Sep 2005
                    • 74
                    Colour me interested! You'll just keep this thread updated?
                    • glucklich21
                      • 1912
                      I can
                      • clavinZERO
                        Hella sick E30
                        • Mar 2004
                        • 2027
                        Is there an update on this of any kind? I am very interested. Would be a nice cheat to get my back brakes to be beefier without having to go full Z3-M!
                        "BMW Style 32 Poster-Child"
                        HTTP://WWW.CLAVINZERO.COM/e30-5-lug
                        **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
                        • stonea
                          • 2892
                          Uses:
                          -Ti Hub
                          -Z4 3.0si rotors
                          -E36 M3 caliper
                          Where is the NSFW warning for this picture?!?
                          Also interested in the brackets too!
                          My Garage
                          Feedback
                          Instagram: Stone.Hopkins
                          • brainfood
                            • Jun 2013
                            • 129
                            This is till the same as the 300.de setup though? The 318ti uses the small wheel bearing.
                            I'm looking into doing e30 325 arms and wheel bearings, Z4 hubs and rotors, and e36M3 calipers. Having a engineering friend build the brackets for it when I get the parts, I'll have a few sets machined if it's not a huge pain and sell that for a little bit more than cost.
                            I guess if people wanted to do a pre-order kinda thing, I could get a quicker start on them. I just planned on doing them a little bit from now, because I'm caging the car currently.
                            WNY e30 Group on FB, feel free to join if you're from the area!
                            @mriterphoto on instagram
                            "Being airborne in an e30 is one of the worst ideas that I've done more than a couple dozen times"
                            me-"I've got one of those rare 7cyl low-comp S62's"
                            MattAvino- "Those aren't rare"
                            • Wishno87
                              • 6025
                              Still interested if this ends up happening.
