M system turbine question
  • Jsturgis19
    • Jan 2016
    • 2
    Im running ti rear trailing arms with e36 front hubs with hub adapters with the m system turbines in 17x8 anyone else running wheels similar if so what size tires are you running?
  • E30-323ti
    • 328
    I run the 17x9 (et22) on the rear of my E30, with either 245/40's DOT R's or 240/625's slicks
    But I have a E28 5er rearend which is closer in track width to the E30 M3.
    Can't use them on the front as they don't have enough clearance for the BBK.
    292rwhp E30 :D
    • Steve Corbett
      • Jul 2012
      • 449
      What? I didn't think the E28 Rear Suspension, mounts to the E30 Body? Different mounting points.
      Steve Corbett
      1983 528E Scrapped
      1983 528E Sold
      1984 745I
      1984 325E - Sold
      1989 325I Bronzit-Sold
      1989 325I Zinno
      1988 635CSI
      • E30-323ti
        • 328
        They are only very slightly different, same style though so easy enough to adapt.
        The harder part is converting to use the rear coil-overs of the E28, means new shock towers are req'd, and the old upper spring perches need to be removed from the body.
        But worth the effort if you need a strong rear-end, and the late E28's have better trailing arm geometry (12° vs 15° sweep angle) and toe control links.
        292rwhp E30 :D
        • e30austin
          • 15382
          I had a very similar setup a few years back. Here's my '88 330is on E36/Z3 5 lug susp. 17x8 M-Systems with 205/40 tires. Unfortunately, the 6 cyl Z3 rear end is not very forgiving to low offset wheels, so it rubbed everywhere. Didn't end up running that setup for all that long.
          • Jb325is
            • 2137
            I ran 17x9 et22 with 245/40 on e30 m3 rear setup.. Rubbed the inside of the quarter panel pretty hard under compression. Only way you'll fit them on a late model with e36/7 stuff is small tires, even with 17x8's
            - '88 m54 coupe
            <3
