My Bastardized E36 5-Lug Conversion
  • BenM
    • 2184
    Originally posted by M-technik-3
    Aren't the strut tube diameter different? Maybe use the M3 upper mounts or redrill them.
    I was working on some Z3M struts yesterday. Cut the tops to insert Koni's as well since I had a line on some Bilstein Sport/H&R race but seller never responded back and they sold.
    I haven't checked the differences, but since I'm using coilovers the difference I was worried about was in the strut nut size.
    What springs are you going with? I know the front E36 M3 are usuable, but E30 are optimal. I really liked the Koni Adjustable Inserts for the 96+ M3/Z3 M housings.
    Originally posted by clavinZERO
    Stock e30 strut mounts will fit with e36 m3 bilstein sports. I am running them myself at the moment.
    Good to know, thanks!
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
    • BenM
      • 2184
      Alright, here's a small update with another crappy cell pic since I still need batteries for my regular camera.
      The rear is all back together and even has the proper ABS Sensor spacers (I can give anyone dimensions if they want). Put on the ASAs with 235/40-17s and holy crap are they big! I will be rolling the fenders this weekend for sure.
      The front is almost there, but I need to do a few things. The front adjustable sway bar links still need to be put on, then preloaded. Still need to figure out what to do about the front ABS since I refuse to splice in the E36 sensors. Might just go without it for a while.
      Also, the car is getting an M50TU tomorrow, so that gives me 3 days to get everything sorted, then I should be able to drive it for an alignment on monday. Then off to V@V on Friday morning.
      2012 F350 6.7PSD
      • BenM
        • 2184
        BTW, in case anyone was wondering, the E36 M3 Koni Front Insert fit fine into the stock E30 Upper strut mount. I plan on shimming the strut to spindle with M30 head bolt washers to get a little more camber.
        2012 F350 6.7PSD
        • jrdeamicis
          • Nov 2008
          • 956
          Just make sure to use longer bolts :)
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
          • Cha Ching
            • 1668
            I know I'm a noob to the e30 scene, but surely some sort of jig and/or fixtures could be put together to make converting e36 325/318Ti/M3 suspension parts fit the e30 a fairly easy, safe & cost-effective swap?!?!
            The parts are plentiful & (relatively) cheap. Enough swaps have been done using various methods and/or parts combinations that there should be several ways to, "skin this cat."
            Bigger brakes, greater selection of wheels/styles, etc. seems like the way to go...
            • bimmer630
              • 1228
              I might pick up a set of E36 M3 koni sport inserts for the front. i am running H&R sport springs... will this setup be cool as far as strut travel? right now with stock M3 front housings i dont have a whole lot of room till the bumpstop touches, and if this is not ideal i dont wanna waste putting nice strut inserts in the housings.
              • rkettner
                • Jun 2007
                • 367
                i think these might help you like they worked for me.
                BMW parts, BMW performance / race parts and online OEM BMW parts catalog.
                • e30jieve
                  • Jun 2011
                  • 5
                  I have set of konis right now on my e30 and planning doing a 5lugs converstion, I have the 318ti stuff for the rear and I'm planning to get parts I need for the front soon to complete the swap.
                  Do you guys know if possible to fit or use my e30 koni front insert on to e36 m3 housing?
                    • 37826
                    Not possible.
                    Classic BMW Specialists
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • BenM
                      • 2184
                      Just to update this thread a little bit, but I'm going back to Spec E30 4-lug stuff on my track E30 (and possibly M20 as well lol). I really liked the suspension setup with the M50 and the braking was phenomenal as well, but as many have mentioned prior the Front/Rear Brake bias on the M3 Front/Ti Rear leaves a little to be desired.
                      I didn't exhaust all possibilities to help the rear braking bias, but I picked up a '98 318ti back in December that needs suspension, and I want to turn this car towards SpecE30. A win-win in my book. :D
                      2012 F350 6.7PSD
                      • bimmer630
                        • 1228
                        We need to find cheap big rotor swap options for rear z3/ti setups!!! I ran mine on the track Saturday and was actually happy with my braking, but if I want to run it any harder I feel like I'm gonna start having issues
                        • M-technik-3
                          • 18946
                          Already been done, see 318Ti.org and check it. Using E46 rear stuff.
                          • bimmer630
                            • 1228
                            Wouldnt the E brake have to be deleted in order to use a rotor that doesnt have the super offset hat?
                            • M-technik-3
                              • 18946
                              Yes, it normal does. Massive was selling a BBK set up for Ti rears as well
                              • bimmer630
                                • 1228
                                Yeah. I tried checking out the 318Ti.org thread but they want me to log in to see it
