5-lug Setup
This is a sticky topic.
  • CrAzY_DrIveR
    • 15
    #256
    so...
    so i can just put the 323ti hub disc calipers to the original e30 arm and keep the same ET as a 318ti complete arm right?
    BTW i thing the 318ti trailing arm gives more toe than the e30 one that looks straight am i wrong?
    Originally posted by Aptyp
    there's also another update I need to add to the side.
    European 323ti uses a larger rear wheel bearing, but the same rotor as the 318ti. This is a way to keep the standard proven bearing and to get extra 5mm space in the rear.
    Cool addition by an Indonesian member.
    • Aptyp
      • 6584
      #257
      yes, you can bolt up all 323ti parts straight to the e30, no issues at all.
      I've stared at 318ti and e30 trailing arms for months, I've NEVER noticed a difference, so I don't think there's a toe difference. Maybe you're looking at different ride heights, that gives you that perspective.
      • CrAzY_DrIveR
        • 15
        #258
        any of you have experience with e39 or e46 abs? I'll be trying to use one of those in the future...
        as for the trailing arm maybe the back of the car is not as large as the middle and that is why it feels wrong...
        Uploaded with ImageShack.us
        • robmespeedy
          • Oct 2004
          • 561
          #259
          on the front end of a e36 m3 swap, are we able to use m3 sway bar links? u know the ones that bolt on to the strut.
          • Aptyp
            • 6584
            #260
            you need to adjust your toe, but getting eccentric TABs or welded subframe.
            yes you can
            • AlpineM325
              • Aug 2007
              • 373
              #261
              Trying to decide on 5-lug wheel options. How much more does the hub stick out compared to stock. Most likely going to go with e36m fronts and have not decided on the rears.
              sorry if my terminology is off.
              WTB
              -convertible carpet, no rips, in socal.
              -s52, s50, m52, m54
              -harness, accessories, transmission
              • CrAzY_DrIveR
                • 15
                #262
                maybe 10 or 15mm more at the front i guess
                • Aptyp
                  • 6584
                  #263
                  good answer crazy driver, I'll have to measure the exact specs, but 10-15mm is good approximation.
                  • AlpineM325
                    • Aug 2007
                    • 373
                    #264
                    wow so much for really low offset wheels huh? thanks guys!
                    WTB
                    -s52, s50, m52, m54
                    • Aptyp
                      • 6584
                      #265
                      I am running ET20 ans know of quite a few people, who run 16x8 ET20 wheels.
                      • CrAzY_DrIveR
                        • 15
                        #266
                        RH 7j 15 inch et13 RH rims 205/55 r15 4x100 is very close to Azev A 16" ET20 7.5j 225/45 16" 5x120
                        • Aptyp
                          • 6584
                          #267
                          I run 7.5 ET20 rim and 205/55 tires were scrubbing too much.
                          • fporro
                            • 1860
                            #268
                            spent a little time at local yard, found a passanger side e46 setup and test fitted to e30
                            had to use e30 upper perches and tower, looks fine but offset grew, easy to see.
                            • Aptyp
                              • 6584
                              #269
                              wow, very nice
                              • eta1987
                                • 235
                                #270
                                I am in the middle of doing my rear swap. Since I am swapping an 89 model car, I guess I can't just use the 318ti hubs and brakes I have? When I took the hubs off of the 318ti axle and tried to put it on the e30 axle, the splines were not the same. I can not slide it on. So i'm guessing i need to swap the whole trailing arm assembly like it says in Aptyp's writeup. My question is then, if I have to use the 318ti axle with the 318ti hub, will the diff side of the axle bolt to my 3.73 e30 diff flanges?
