so my mtechnic is lower on the passenger side
  • ///M42 sport
    • 3952
    Eversince I've owned it, I've always thought it sat kinda lopsided. I finally measured the corners from the centercap to the top of the wheel well and found out its sitting about 1/2 inch lower on the passenger side. Any ideas on what could cause this? shocks or springs?
  • Jon325i
    • 6934
    Could be worn parts....maybe mismatched springs. Is this car completely stock or did you get it with mods installed?
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • elemental
      • Jan 2004
      • 112
      Re: so my mtechnic is lower on the passenger side
      Sounds like your springs might be saging unevenly I would Jack the car up and see if the springs are fully seated in the spring perchs..
      • ///M42 sport
        • 3952
        Thanks, I'll check the spring pads. Only mods on it were a LSD and offset control arm bushings.
        • BahnE30
          • 1050
          pffft mines the same way
          it's only out 1/4 thou i'm not to worried about btw it's got all new suspension under it and i had it on a frame machine
          po thought he might have tweeked it when he hit a curb but everything checked out straight
          • ///M42 sport
            • 3952
            weird. Yours is a coupe?
            • M-technik-3
              • 18946
              Springs installed the correct way in front?
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Most cars come like that from the factory. Have someone around 180lbs sit in the driver's seat, it'll be even.
                • ///M42 sport
                  • 3952
                  damn, I'm only 140.
                  • BahnE30
                    • 1050
                    yup, mines a couple
                    i think it might have something to do with the battary on that side
                    i'm doubtful but thats the onlything thats on one side but not the other
