rear subframe help
  • BimmerToad
    • Sep 2004
    • 1537
    rear subframe help
    I'm trying to remove the rear subframe, trailing arms, and differential as a whole unit but it doesn't seem to want to come out. I've undone the brake lines, diff mount, shocks, sway bar, driveshaft, 2 subframe bolts, speed sensors, exhaust, and removed the parking brake cables. Any thing I'm missing? Should I just start hitting the subframe with a mallet? :twisted:
    San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
  • Jordan
    • 12916
    Prybar.
    https://mtechniqueabs.com/
    • Skafrog
      • 1732
      get a side cutting drill bit and cut out the bushings. They are probably stuck on the posts. After the subframe is out, then break out the BFH and go to town on the posts, then work on getting the corroded nubs out of the slots in the chassis.
      If you are pulling the subframe, this would be a good time to replace the bushings (I assume you haven't yet)
      NASA MidSouth TT Director / GTS2 #018
      Mods: Coastal PS Fluid, 10w40 Oil
      Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
        • 34847
        smack it with a mallet, spray some penetrating oil into the bolts. you can also take the rear seat out and smack the bolts from the bottom (thread a nut on them) to knock them out. you might also have to wiggle the subframe around a bit. it's not too hard, but beware, it's going to be pretty heavy with all the parts on there.
        • Stu Mc
          • 4083
          A lady's foot tool really helps when jerking the subframe loose. Those bushes are pressed to the body, they've had the cars weight on them for 15 years, and they need a hell of a jerk to come loose (usually).
          • BimmerToad
            • Sep 2004
            • 1537
            I let the subframe bolts soak in penetrating oil overnight, so it sounds like I need to just start pounding/prying away. I just wanted to make sure I wasn't forgetting anything ;)
            • fporro
              • 1861
              Spray it with PB 40, then place a jack under trailing arm, release the rear shock, the tension on the springs will push down and brake it free. at least that's what i did.
              • rwh11385
                lance_entities
                • 18403
                word.
                only be careful with BFH. those posts are a PITA to get out of the body if they break. try to try the posts out first and spray some PB Blaster to try to help. And pop those bolts up too.
