Problem
  • Bunta
    • Nov 2004
    • 64
    Problem
    Trying changing the front left arm, i've broke the screw (number 10 on picture).
    BROKE ON the carbody....
    what can i do
  • Charlie
    kid tested, administrator approved
    • 6686
    What do you mean "Broke", like broke the head off?
    If so, undo the other one, remove the arm, get out your dremel, notch a decent ridge in what's left of the screw body and get a big flathead screwdriver.
    FWIW, since Dremel might not be available in your area, and I have no idea how to say "reciprocating saw" in french, here's a pic of one:
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • Bunta
      • Nov 2004
      • 64
      -Charlie
      Yes head off...
      But i seems so difficult to unscrew that i think it is the end....
      • Charlie
        • 6686
        -Charlie
        Yes head off...
        Do you think you cross threaded it or stripped it? I would try my "dremel" approach first, if that doesn't work, you might have to try getting a helicoil kit.
        -Charlie
        FYYFF
        • bmwannabe
          • 900
          get an easy out attachment for your drill, and go to town with that. Shouldnt be too hard.
          • Bunta
            • Nov 2004
            • 64
            -Charlie
            I don't know.
            i'm fed up with this car
              • 34844
              you must have some rust problems, or somebody went nuts with air tools.. those bolts are only supposed to be torqued to 30ft-lbs, not exactly the tightest fasteners on an E30. you should be able to break them free with a small wrench.
              if you take the rest of the bolts off, you should be able to get the control arm bracket off the car. Then you can use a set of vice grips on the rest of the bolt that is sticking out. hopefully it's not cross threaded or something. use some penetrating oil to make it a bit easier, good luck!
              • Bunta
                • Nov 2004
                • 64
                I think this was very badly repaired in its old life.
                I'll tell you guys, the end of this story.
