Eibach sways and treehouse bushings install questions
  • Brew
    • 3060
    I cut mine off with a die grinder. :twisted: Obviously ruined the factory "lollipops", but I replaced them with the treehouse cabs.
    '91 318is
    • Ryan Stewart
      I Love Miatas
      • 8978
      The two must have automotive tools are a good torch and a Saw-zall.
      Im now E30less.
      • 808BMW
        • 2910
        Yeah, we were thinking of torching it off. The problem isn't the big rubber bushing, it's the little metal ring thats on the controll arm, I thought it was rubber, but it isn't.
        • aaron_silva
          • 1785
          Originally posted by m42technic
          Originally posted by Skafrog
          look, you cant install the bushings the wrong way.
          You can also slide them on/off with your pinky finger, so it wont matter if you happen to mess up the first time.
          I actually had a hell of a time getting one of mine to slide on...
          Ditto. One side was a bitch and the next side slid on with ease.
          Aaron
          • Skafrog
            • 1732
            Aaron
            Damn, are you guys mushrooming the end of your control arm when you get the old bushing off?
            NASA MidSouth TT Director / GTS2 #018
            Mods: Coastal PS Fluid, 10w40 Oil
            Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
            • kencopperwheat
              King of Kegstands
              • 14396
              Jordan said he cut through that with a dremel.
              Originally posted by Gruelius
              • m42technic
                • 1056
                Aaron
                Brand new control arms.
                James Peacock
                WWFSMD?
                  • 34839
                  are you putting in OEM or polyurethane bushings? if so, they have to be pressed in anyway, so there's no need to cut out that ring. the old bushing will be pressed out when you have the new ones pressed in.
                  • Victell
                    • 1081
                    Q & D. Get one of these c-clamps from your hardware store. Cheap & easy.
                    EDIT: for removal only
                    • 808BMW
                      • 2910
                      THR solid CAB's.
                      Well I'm out of cutoff wheels, and my car is up in the air on jackstands, so I guess I'll have to grab some later and cut em off.
                        • 34839
                        I dunno, if you're not replacing the control arms cutting them off seems like too much work. with a torch, all you really need to do is get them hot, you don't have to burn out the bushing or anything. then they just slide right off..
                        • 808BMW
                          • 2910
                          Seems like the bushing is coming out, that's bad right? Just fuck me in the ass already this is pissing me off
                          • jasonk
                            • Oct 2004
                            • 148
                            Ah, crap, maybe I should rethink installing these
                            • royalflush313
                              • Mar 2004
                              • 2070
                              did you paint it with a clear?
                              ~ Go Canucks Go! ~
                              • 808BMW
                                • 2910
                                Nope, paint is fux0rz anyway, i just want to get this on so I have a vehicle
