Having GC's set very low + worn to hell subframe bushings equals me eating through tires quite often, considering my relatively low amount of abuse I put on them.
I'm getting some things, maybe anyone has any ideas on other stuff I should get while working in this area?
Planning on getting the following so far:
Camber/toe kits for the rear
TA bushings
Subframe bushings
Do I also need eccentric bushings along with the camber/toe kits?
I'm planning on getting 20mm spacers and a stud kit, how does that work? I need 90mm long studs? Where should I get these?
I was planning on buying the alignment stuff and bushings from IE, or is there a better choice? If I chose to go with urethane bushings (street, not race) is there going to be a large difference in ride quality? Right now the plan is to go with stock, I already have a stiff ass suspension and really don't want to make it worse. If anyone has noticed no difference in stiffer bushings please let me know.
TA bushings
Subframe bushings
