installing suspension...
  • SLEEPERracer
    • Oct 2004
    • 215
    i was wondering if you need to torque down anything to a specific level when reinstalling the front strut assembly or anything in the rear. thanks!
  • Dave
    E30 RAT
    • 11675
    yes, you do
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • Brew
      • 3060
      Originally posted by DaveCN
      yes, you do
      Yeah, lugnuts. 90ft/lbs
      Everything else should be be tight enough to not back out or cause play, but not so tight that you start breaking shit.
      Although, since you're asking you probably should get yourself a Bentley manual, which has all of the torque specs you need.
      '91 318is
      • SLEEPERracer
        • Oct 2004
        • 215
        thanks!
        • Digitalwave
          is a poseur
          • 6300
          Caliper bolts are 91ft/lbs, I always torque those to spec. Same with the wheel nuts. The top bolt for the shock is hard to torque to spec, and the control arm and tie rod ends I just crank down.
          RISING EDGE
          • Dave
            E30 RAT
            • 11675
            So true. I did not provide that as he did not ask for it. I answered the questions exactly as he asked it. ;-)
            Current Cars
            2014 M235i
            2009 R56 Cooper S
            1998 M3
            1997 M3
            • E30 Wagen
              How do you know when you have the correct torque? A special tool/gauge?
              • asubimmer
                • 6482
                umm...a torque wrench
                • SLEEPERracer
                  • Oct 2004
                  • 215
                  wel i put the fronts in and it just raised the car. i dont think the coilovers i ordered fit the strut i have. i got the ones the fit oem and tokico shocks. what i have is an oem strut with a tokico shock. anybody could help me out cause i even put the lock on the perch all the way down and still the car was high. anybody have any idea whats up? thanks!
                  • Digitalwave
                    is a poseur
                    • 6300
                    What coilovers are they? Spring lengths and rates?
                    RISING EDGE
                    • SLEEPERracer
                      • Oct 2004
                      • 215
                      i finished the job yesturday but wen i lowered the car from the lift it stayed high. like higher than stock or stock height! my spring rates are....
                      front-
                      GC150.64.66
                      rear-
                      GC140.64.83
                      Front: 6" spring height, 2.5" spring diameter, 375lb/in spring rate
                      Rear: 5.5" spring height, 2.5" spring diameter, 475lb/in spring rate
                      • browntown
                        • Jun 2004
                        • 3524
                        I dont have coil-overs but isn't the point that you can adjust the ride height? Try turning that collar down. Also dont you need shortened strut bodies for coilovers? No need to skylift your e30.
                        • Digitalwave
                          is a poseur
                          • 6300
                          You really need to cut the stock lower spring collar off of the stock strut tube and reweld the smaller GC perch if you want to drop the car down low.
                          RISING EDGE
                          • Alpine-E30
                            • Mar 2006
                            • 161
                            You don't have to remove the calipers to do the front suspension.
                            Compress the spring on the car
                            remove upper mount
                            remove locking cap for strut insert
                            slide strut insert out through tower
                            replace spring with new spring
                            slide new insert in and tighten cap
                            install top mount
                            uncompress spring
                            job done.. Take about 30 minutes per side in the front.
                            Signature removed by R3VLimited staff due to a violation of the signature rules
