Allignment specs
  • Avus E30
    • 3650
    Allignment specs
    I had an allignment done this morning and as I assumed all my specs are off. I am curious though as to if these are acceptable ranges for the car. I don't really know much on suspension but I know I dont wanna burn the new tires off. If there is anything to suggest to correct the problems let me know.
    HDE30 <3
  • E30-323ti
    • 328
    The camber is very unbalanced left to right, and toeing out on one of the rears (poss. bent subframe).
    And not enough castor, but it is balanced left/right, did you put some M3 offset CAB's in backwards maybe??
    Tie wear should be OK, there isn't too much toe in or out which kills tyres.
    It will however be handling like a dog with specs like that.
    292rwhp E30 :D
      • 34839
      the front really isn't a big deal, but you don't want toe out in the rear.. something is either bent or your subframe/trailing arm bushings are toast.
      • Avus E30
        • 3650
        any other opinions?
        HDE30 <3
        • E304life
          • Jul 2005
          • 123
          Considering how old e30s are thats not to bad.
          The only thing you can adjust on stock e30s it front toe.
          If you are realy worried about it you can get adjustible caster/camber
          plates, and rear eccentric trailing arm bushings, then you would be able
          to adjust all the importian specs.
          Majority of cars that have been on the road for 4 or 5 years are out of spec, some are even out right from the factory.
          • PУCCKAЯ_e30ka
            • Jan 2006
            • 1226
            I have rear right camber -1.4 and toe -0.63..... rear total toe -0.59 is that really bad.. i know my bushings are shot, but if I'll put in new urithane, will that somewhat fix it? or is the subframe definately bent?
            • E304life
              • Jul 2005
              • 123
              I cant say for shure, its hard to tell with the naked eye when things are slightly bent. I gess I would replaced the bushings and then install the IE rear eccentric bushings/bolts.
              I dont think i have ever done a alighment on a e30 were the rear was in spec. Like i said befor e30 are just old and have seen lots of pot holes and
              curbs in there day.
              The nice thing about the adjustable rear eccentrics is it can compensate for
              slightly bent suspention components.
