brake lining light
  • bert
    • 306
    brake lining light
    this thing is driving me nuts...when i first
    bought the car, it would come on sporadically...
    and, depending on how cold the temperature
    was, i could get it to go off by applying finger
    pressure to the trim piece directly beneath it...
    now that it had warmed up, it's on all the time
    and nothing i do short of bulb removal will make
    it go away...everything else on the cluster works
    fine and i would really like to retain the original
    unit if possible...
    is this a cluster issue or an si board issue?
    bert
  • DarkWing6
    • Apr 2004
    • 7144
    isnt this the same thing I am discussing in my post General Discussion? haha. You posted in there too.
    • bert
      • 306
      yeah. you're problem is a bit more serious,
      but kinda similar to mine...the more i started
      thinking about my brake lining light, the more
      annoyed with it i suddenly became...
      bert
      • James Crivellone
        Head Janitor
        • 6304
        if your pads are fine then replace the sensors on the 2 pads (Left side of the car) (Rear may be in the right, I forget)
        they are like 5 bucks each, if it really gets to you then just remove the lightbulb
        • bert
          • 306
          it's not the pads and sensors--they were just replaced...
          and the bulb was on before...
          the car is in almost perfect condition and i really don't
          have an interest in a 'quick fix' like pulling the bulb...i
          prefer to have all the systems on the car to function as
          originally intended...
          bert
          • James Crivellone
            Head Janitor
            • 6304
            bert
            okay, then why don't you check all the harnesses that go to the sensors, make sure they work, make sure all connectors are tight and not corroded.
            That light runs on its own little system, and does not talk to the SI Board at all
            • bert
              • 306
              a valuable piece of info...thanks...
              bert
