steering wheel knocking when turning
  • E30godz
    • 1524
    whenever i turn the steering wheel like in a tight space situation (or just low speeds i guess) with lots of throwing the steering wheel back and forth, it knocks very noticeably. like every revolution or so it does....is this that big nut on the steering column or something else?
  • DaN
    • 1265
    Could be a loose ball joint or something shifting in the suspension when you turn the wheels. You can check the steering wheel nut, but thats probably not the problem.
    Perhaps you should also check the rubber coupling on the steering shaft in between the steering rack and the firewall.
    Thats all i can think of.
    • aaron_silva
      • 1785
      I had a similar problem. It went away with upgraded shocks.
      Aaron
      • Rob
        • 8166
        mine does it too, ever since I put in the momo wheel
        BEERTECH
        • Digitalwave
          is a poseur
          • 6299
          It sounds more like something along the line is getting snagged at a certain point, since it happens once every revolution. Want some pancakes?
          RISING EDGE
          • E30godz
            • 1524
            im more in the mood for waffles, thanks.
            • Erick
              Official R3V Drifter
              • 11169
              Do you have the stock steering wheel?
              If not, did you remove that white peg in the steering column? My MTech1 wheel did the same thing when I replaced the airbag wheel with it.
              I pulled that sucker off and everything works fine now.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • LennysEleven
                • Mar 2004
                • 163
                Could a worn out Guibo cause loose steering?
                Sorry if this is OT
                • e30Matt
                  • 5077
                  Shit, same here... anyone know what that little plug was for? Someone told me it was airbag related.
                  • Digitalwave
                    is a poseur
                    • 6299
                    Sorry if this is OT
                    No, the guibo is on the drive shaft, its not even closely related to the steering.
                    Matt, it holds the ring that controls airbag deployement. You have to take it out when switching to a non-airbag wheel.
                    RISING EDGE
                    • e30Matt
                      • 5077
                      Sorry if this is OT
                      Ahh, thanks.
                      • Digitalwave
                        is a poseur
                        • 6299
                        Yeah, I had to learn that the hard way. When I swapped my wheel it made a terrible noise, it took me a few days to figure out it was that part.
                        RISING EDGE
                        • Rob
                          • 8166
                          do you have to pull the hub to remove this?
                          BEERTECH
                          • Stu Mc
                            • 4083
                            Sorry if this is OT
                            l.
                            Yes, there is a guibo on the driveshaft. There is also one at the steering joint above the steering rack. It wears over time and can cause things like steering clanks and sloppiness.
                            :idea:
                            • Digitalwave
                              is a poseur
                              • 6299
                              Yes, its a white tab that is spring loaded.
                              RISING EDGE
