Sparco Strut Bar Not Fitting!
  • Matt86es
    • Aug 2004
    • 616
    I just tried to install my new Sparco Front Strut Bar that i got from the group buy. The fuse box is in the way and preventing it from bolting up correctly. Is this supposed to happen and how should I fix it. I think that I can grind a notch in it so that I won't have to relocate the fuse box.
  • Jand3rson
    • 37587
    Re: Sparco Strut Bar Not Fitting!
    Relocate the fuse box, that's a good one. :D
    Sorry...
    • rs4pro3
      • 5808
      They look they they will hit the fuse box when you just line it up, but once you start bolting it down, just pull the bar into place. Most bars won't slip right on, mine had to be bent some to fit.(non sparco)
      85 325e 2.7 ITB'd stroker
      • Mystikal
        Wheel Fitment Expert
        • 9602
        It will fit. Think creative and bend that throttle cable. There's not much more to say, but it does fit.
          • 37832
          Obviously it will fir man, TONS of people have them... You have the power...
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • Bryson
            • 1490
            haha.
            stupid ass.
            • Beej '86 325es
              • 2639
              I think you're having the problem I had when I put my RD bar on. Nobody else had the problem, but it must be because you have the same year and model as me.
              The problem I had was that the fuse box bolted to the top of the tower and was in the way. I just took a hack saw and cut a piece out of the plate part of the bar that mounts to the top of the tower. I wasn't able to bolt the fuse box back up to it, but there are so many wires going into it that it is secure enough without it.
              Does the Sparco bar bolt up to 2 or all 3 bolts on the tower though? If it's just 2, you might not be able to do what I did without compromising the strength of the plate.
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • Digitalwave
                is a poseur
                • 6299
                If that doesn't fix your problem, then your car was in a serious wreck which bent the strut tower severly. Sell your car.
                RISING EDGE
                • Bryson
                  • 1490
                  sorry i was drunk last night, no offense to you personally
                  • Matt86es
                    • Aug 2004
                    • 616
                    Got it on!
                    I'll let it go, but I will let you know that it did not fit originally. Like the other guy said, there's something about my exact model year. I had to shave a notch about 1/4" in with a grinder so that the corner of the fuse box could fit in it. I don't think that it was enough to affect the structural integrity of the bar.
                    • zandi
                      • Apr 2004
                      • 602
                      Dude matt, I had the same problem, but somehow, I did it. You can do it, and if you can't fit it, try jacking at least one side of the car near the front and try different lengths, an extra hand would help.
