Sparco bar on a m42
  • royalflush313
    • Mar 2004
    • 2070
    Sparco bar on a m42
    so we tried to fit the bar on my 318is, but it seems like the bar will touch the intake manifold - i could only imagine the horrible vibrations that may cause to the car.
    Anyone have any advice? I could throw on some washers to raise the bar up a bit, but then it probably wont leave enough thread to tighten the nuts properly?
    thanks.
    ~ Go Canucks Go! ~
  • Rob
    • 8166
    search, as TJ installed one on a friends m42
    BEERTECH
    • e30Matt
      • 5077
      Re: Sparco bar on a m42
      thanks.
      A guy I know just shaved the intake mani slightly to clear the bar.
      • 318daily
        • 507
        get a different bar. I had to try 3 different strut bars on my M42.
        • e30Matt
          • 5077
          Why?
          The Sparco will fit fine with VERY simple modification and it's the best bar you can get for cheap.
          • Digitalwave
            is a poseur
            • 6302
            With just 2 thin washers on each stud, we were able to fit it fine onto an M42. That left enough thread for the top nut to thread on completely and be torqued to spec. It was really close to the intake manifold, but even with revving the motor up and letting it torque around a bit, it didn't hit the bar at all.
            RISING EDGE
            • royalflush313
              • Mar 2004
              • 2070
              alright thanks. Will try that.
              ~ Go Canucks Go! ~
                • 37834
                Grover Beach, California
                BimmerHeads.com
                • 318daily
                  • 507
                  congrats.
                  • m42technic
                    • 1056
                    I dont know about you guys, but stacking washers ot get the bar to fit wouldnt be my cup of tea...
                    James Peacock
                    WWFSMD?
                    • e9nine
                      • 1890
                      Originally posted by m42technic
                      I dont know about you guys, but stacking washers to get the bar to fit wouldnt be my cup of tea...
                      :stupid:
                      • boom-monkey
                        • 1104
                        It was my car that we stacked the washers on. I really dont see it as being a problem since with my bar I will put the 3rd bolt hole so the chassis will be absorbing the lateral motion and not the studs. In essence all the studs are doing is holding the bar from coming up off the strut, while the rigidity is coming from the pressure on the chassis.
                        • e9nine
                          • 1890
                          Not saying it's a bad thing. I just wouldn't do it.Purely personal choice.Even If I were to go this way, I would use longer studs as I mentioned in the other thread.
                          • e30evolution
                            West Werks
                            • 1888
                            how would longer studs space the bar from the strut tower?
                            http://www.westwerksauto.com
                            • Rob
                              • 8166
                              they dont, but they allow more threads when washers are used
                              BEERTECH
