Problem with brake booster ATE
  • 325IS89
    • Oct 2025
    • 2
    Hello everyone,
    I own a 1989 E30, 325i. I have a problem with my ATE T52 10-inch brake booster, OEN 34331157416.
    Unfortunately, I have an internal leak in the vacuum system.
    The part is no longer available new from car parts dealers.
    My questions:
    - Do you know if there are any parts from another car model that would fit without modification?
    - Does anyone have a new part in stock?
    - Has anyone ever had their brake booster serviced?
    Thank you all and sorry for my English, this is a Deepl translation, I am French :)
  • Dagamus(NM)
    • 621
    Is the leak in the booster or another part of your vacuum system?
    Seems available to me: https://www.pelicanparts.com/More_In...lI5QYpP9xFPMzP
    Check the hoses around your throttle body and the big one to valve cover. If no obvious leaks there then it could be the booster.
    Why is there a rag under the master cylinder and where is your reservoir?
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
