Upgraded from Massive Big brake kit to a BBK of my own design...
  • newman
    • Mar 2007
    • 1159
    Made 2 new mounting brackets and made 4 of these: (2 spares)
    BEFORE:
    AFTER:
    11.75 x .81 w/ 4 piston -> 13 X 1.1 w/ 6 piston
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
  • newman
    • Mar 2007
    • 1159
    it actually cost me less to make my own kit even though it had bigger stuff...
    • Jean
      • 18228
      Wow, they look huge! My r32 had 13" rotors, talk about stopping power with good pads/fluid! I can't tell what car that is though?
      • newman
        • Mar 2007
        • 1159
        It's an E30 w/ a built skyline GTR motor in it.
        • Jean
          • 18228
          Ahh yes, I see the front tow hooks. Batshit insane!
          • E30_fiend
            • Apr 2006
            • 7348
            badass.
            now make a set for me
            • Massive Lee
              • Sep 2006
              • 6785
              Nice work. But you could have reduce the weight of the rotor by using units with less friction surface (annulus) as it seems the pad is not scrubbing all the rotor. Use a rotor with a larger PCB - bigger hat, less friction ring. And as you now have bigger rotors, I am sure you could have positionned the caliper parallel to the mounting points. 8-)
              massivebrakes.com
              • newman
                • Mar 2007
                • 1159
                Good thinking about the mounting points, I didn't think of that. However, I couldn't go any thicker than 1.1, and 13" was my max rotor size, so that pretty much locked me into the 12 X 7.00 bolt circle.
                • z31maniac
                  • 17566
                  Excellent work!
                  www.gutenparts.com
                  • scott_is
                    • Aug 2007
                    • 310
                    Do you happen to know the weight difference between the massive kit and yours? Is the weight similar?
                    Scott
                    • kishg
                      • Sep 2006
                      • 2624
                      not sure how much of an upgrade it is.. more weight, seems to be same swept area by the piston or even less? maybe it's the pictures..
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • newman
                        • Mar 2007
                        • 1159
                        Scott
                        The swept area is increased by 15%
                        Stationary weight probably the same or less, rotating weight increased by 6lbs, though...
                        The rotor i basically had to use was 14.5 lbs. If I could have jumped to a 1.25 thick rotor, I could have cut it to 12.5 lbs, but was unable to do so, because it would require either 500 dollar calipers or more wheel spacer...
