Installing hydroboost on your e30
  • flyboyx
    • 8371
    Originally posted by Pootis
    Looks like it's going to work I haven't done the full testfit yet. I tried a gm booster and that thing was way too big but this is half of the size of that monster so I'm thinking it's going to work. Motor wasn't even bolted down in this pic.
    that is actually a cardone unit you have in your hand. you have it upside down by the way. you can rotate it about 120 degrees clockwise and it should work for you. for some reason, i am told the ports need to be toward the top of the unit when its installed. i would suggest using that over the bmw parts.
    you are going to need 2 custom brackets. one for the firewall side and one to match your bmw master cylinder.
    the advantage of this one is that it only uses two pressure hoses instead of 4 and it uses only one return hose instead of 4. you also don't need to find a place to mount the remote accumulator either since it is built into the unit.
    Gigitty Gigitty!!!!
    • Pootis
      • 636
      That is a unit out of a 94 Chevy Astro. I have done tons of research on it and you can mount it anyway you would like the issue is the thing is way too big for the way my mounts are setup. I understand the BMW unit is a bit more complicated but it is doable I don't see why you can't T the return back to the ls resvoir. Sikky's hydroboost kit basically uses the chevy unit with custom adapters
      1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
      COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
      • flyboyx
        • 8371
        yes, sikky does indeed use this unit with 2 custom brackets. they are all about the LS engine. since they are able to use it, i would suppose you could as well if you chose. perhaps you simply don't want to incur the 1300.00 expense of what sikky sells? some things are well worth what you have to pay for them.
        i would bite the bullet and pay the price they ask except i am running an s62. they don't think it will fit and neither do i. i offered to do a little r&d work for them in this respect. we will see.....
        here is another possibility more along the lines i am thinking of. who says you need to have the booster on the firewall? this will enable you to put it anyplace you wish. even the trunk i suppose.
        http://www.amazon.com/dp/B00BMVK8ZI/...I13YDUKWO3Q642
        Gigitty Gigitty!!!!
        • flyboyx
          • 8371
          in doing a little research, i came across this eBay ad. i think this could be a viable option for bmw v8 engines. this adapter is 190.00, the booster can be purchased for less than 150.00 new. the slave cylinder they recommend is 21.00 at advance auto parts. all thats left to do is fabricate a bracket to run an oem clutch master cylinder for the brake, make an adapter for the oem brake master, run the 2 hydraulic lines between the booster and ps pump, a line between the master and slave, and the front and rear brake lines. i think this setup is viable for less than 600.00. i also think this will provide much better braking than the booster less wilwood setup.
          http://www.ebay.com/itm/201517445988...%3AMEBIDX%3AIT
          Do you want to move that unsightly hydroboost unit from the firewall on your custom machine?
          The Hydroboost relocation kit by Technical Design Services is a precision fabricated system that works with an off-the-shelf slave cylinder, engineered for the DIY mechanic that will save you up to $1,000 compared to other available products.
          This kit is designed to remote mount the hydroboost unit and master cylinder.
          Mount the unit anywhere space allows and run a single hydraulic actuator line to it, just like a hydraulic clutch.
          The mounting feet provide 1" of clearance under the unit as positioned in the factory orientation.
          For hot rods, rat rods, crawlers and buggies.
          About the kit
          This kit is made by Technical Design Services in San Antonio, TX.
          The Adapter and Flange are made from solid 6061-T6 aluminum barstock.
          The mounting feet are made from 11ga A-36 cold rolled steel.
          Benefits:
          All in One design
          Easily mounts by welding feet to your frame or drilling mount holes
          Lowest profile design for clearance
          Allows for more engine compartment space
          Hides unsightly HB unit on show cars
          Please check for clearance in your application before purchasing.
          The following items are included in the kit:
          1ea, master cylinder mounting foot - steel
          1ea, adapter mounting foot - steel
          1ea, hydroboost adapter - anodized aluminum
          1ea, retaining ring - steel
          1ea, slave cylinder adapter flange - anodized aluminum
          2ea, 5/16-18 x 1-1/4" long hex bolts - zinc plated GR5
          Additional items needed, not included in this kit:
          1ea, hydroboost unit
          1ea, slave cylinder, p/n 37793 from Advance Auto
          Free Shipping to US48.
          Gigitty Gigitty!!!!
