Installing hydroboost on your e30
  • flyboyx
    • 8371
    I have been working on an S52 swap for the last few months. as an alternative to using the standard modified e21/rabbit/944 booster that most everyone uses in their cars these days, i elected to go with an option that gives me more braking power. this info is also on a thread in the 24v swap section, but i was thinking more of you could take advantage of it here.
    i know...you are probably asking why i would want to install this on my car. well...i ask you, why the hell not? i have already modified a rabbit booster that i am sure would work fine. i just want more braking power. i have hydroboost on my diesel f350 daily driver and i love the system. i expect i will love it just as much on my bimmer.
    on the right side of this photo are the brakes i am using on the front of my car.
    a few months back, i picked up the system from an old e24.
    everything was fine and dandy until i installed the engine.
    i think it would work out fine if the engine were something other than m/s5x. there is no way around the conflict with these parts. the good news is that i read a thread a while back that you can use the hydroboost system of a 7 series e23. this is what i found at the just yard this week. if you are going to add hydroboost to your e30 with a 24v swap, it is going to have to be the booster from the early 7 series. notice how about a third of the booster is actually inset behind the firewall. this will get you the relief you need to clear the throttle body. the e23 is at the top, the e24 is below.
    also worth noting in the photo above: the upper booster has an extra fitting between the rear port and the pressure hose. this is a restriction for applications with abs brakes. there is a little orifice with approximately a 1/64" hole drilled through. if you have abs and you plan for them to work, you will need this part. it is listed in real oem and priced somewhere around 25 bucks from the stealership.
    an added benefit to going with the hydraulic brake syst is that the diameter of the master cylinder is much larger than the one from the e30. e30 on the left, hydroboost mc on the right for comparison
    here is a photo with the e23 booster installed. the intake boot and maf will pretty much fit with out conflict at this point. the rear orifice on the bottom of the intake boot has slight interference with the hydraulic line on the front of the master cylinder, but there won't be any issue connecting the hose.
    i found a nice out the way place to mount the hydroboost reservoir. originally, i wanted to locate it on the driver side motor mounting bracket, but the top needs to be mounted above the brake booster. otherwise, the fluid could drain back and overflow.
    the accumulator is going to be mounted below the booster on the driver side. i cut the mounting bracket off the e23 so it would be a little easiser to fabricate.
    i went through the 20 or so power steering hoses that i have laying around in search of suitable ends for my project. using my angle grinder(with a thin cutting wheel), i ground off the metal swage collars and slid the ends out of the old hoses.
    doing a little googling on line, i found http://www.discounthydraulichose.com they sell the R1 hydraulic hose needed for about a buck a foot. this is a 2500 psi hose. the working pressure of the system according to my bently manual is about 1400 psi max, so this hose will work nicely.
    they also sell a crimp collar shell for about a buck each.
    unfortunately, they don't sell banjo fittings. i talked to a salesman about it, but he said suitable suppliers are unavailable. i did a little searching and found a couple of aeroquip fittings in their catalog, but for most connections, you need some sort of elbow after the attachment. this is why i am reusing my old fittings. when the hydraulic parts arrive in the mail. i will just cut my hoses to length, assemble them and take them to my local hydraulic shop to get them crimped.
    i have read a few threads on the forums with people complaining that the hydroboost system is unnecessarily complicated. i don't think so. you definitely have more hoses to run and you have to figure out how to locate the accumulator, but really, it isn't bad.
    the reservoir has been mounted, it is a bit tight against the maf. i may move it a little later on.
    here is a photo of the accumulator with the high pressure hose fittings mounted to it. that is the factory bracket from the e23 but turned upside down. on the hose fittings, i left part of the crimped collar where it attaches to the metal line because as you can see in the photo, those high pressure fittings don't have much of a barb on them. some of the newer fittings on the power steering pump don't have any barb at all. once i have the collars crimped on, i plan to put a couple of (tig) tack welds between this flange and the collar for good measure.
    these are the fittings i came up with for the power steering rack and the ps pump
    here is a photo of the e23 accumulator bracket with a notch ground out to fit the brace on the front strut tower. keep in mind that this will be welded to the frame up side down.
    its a little hard to see in the crappy photo, but there is the up side down bracket welded low on the frame with the accumulator bolted on. the bracket is just below the bank of brake lines, just behind the motor mount bracket, and just in front of/and above the steering u-joint. the fuel lines and the carbon canister hose touch on the back side. there is about 2 or 3 inches of clearance to the master cylinder/hydro booster above(removed for clarity). the biggest reason for mounting it that low was that i felt i needed to stay away from the brake lines. i didn't want to weld on a bracket that had a cut out for those lines only to have the possibility of replacing one later.
    Gigitty Gigitty!!!!
  • flyboyx
    • 8371
    i had the hydraulic hoses made for my hydroboost brake setup this week. here is a pic.
    the 4 hoses at the top of the photo are the return lines between the reservior and the 4 components. they are r101 hydraulic hose. they had to come from a hydraulic shop because pep boys and autozone do not carry this stuff. you can see in a previous photo where my reservoir is located. assuming that you choose this same location, you can buy 2 feet of each hose and that will give you about an extra foot for the small one and about an extra 5 or 6 inches for the other three. the hose sizes are 1/4", 5/16", 1/2", and 5/8". the shop i picked up the hoses from only had blue for the 5/8"s so i intend to change it when i get the chance.
    also in this photo, you can see what i did for the pressure lines. the upper one routes between the power steering rack and the side of the accumulator. the second pressure hose runs between the power steering pump and the larger orifice on the back of the accumulator. the lowest hose in the photo goes between the smaller orifice on the back of the accumulator and the rear orifice on the top of the hydro boost.
    the pressure hose is 3/8". i purchased this and the shell couplings on line at discount hydraulics. the hose was about a buck a foot and the couplings were about a buck each. i purchased twelve feet of hose and twelve couplings in case i screwed something up. the pressure hose is R1 and rated to about 2300 psi. according to my bently manual, the power steering system pressure is about 1400 psi max, so this lends a nice cushion. the i cut the hoses to length and fit them to the fittings that were already installed in place. you will need to mark the hoses in relation to your fittings because you cannot allow them to rotate. once they are crimped, you will not be able to make any adjustment. as i mentioned above, i used an angle grinder with a thin cutoff wheel to cut the crimp off of the old fittings. now that all of the fittings have been re-crimped, i am going to tig weld the left over flange to the new crimped shell. there are two flare fittings that i had to cut off short to make them work for my application. since they didn't have a flange to weld to, i slid a 12mm metric nut over the tube. this nut will be welded to the tube and then in turn welded to the crimp. my local napa store makes hydraulic hose assemblies. i took my hoses down there and they crimped them for free. i just tipped the guy ten bucks. all together with all of the parts(new and used), i have less than 150.00 invested in my hydroboost system. this doesn't include the price of any welding, because i handled all of that myself.
    a word of wisdom on scrounging used fittings: if you can't find the right flare fittings for your application, you can use the banjos for the three smaller orifices because the threads are the same. i was actually planing to use a banjo in a couple of places, but i found that i could just cut a metal line, stuff it in a hose and put a crimp on it. i think it is pretty important to weld the universal crimp shells to old fittings because you can't afford to have one of those suckers blow off when you are out on a drive a couple hundred miles from home. the old fitting have very little barb on them and the newer style have none at all.
    Gigitty Gigitty!!!!
    • Staszek
      • 2533
      I wish these pics were still here!
      • Pootis
        • 636
        Same!
        1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
        COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
        • Massive Lee
          • Sep 2006
          • 6782
          Hopefully, this thread will get back to life one day. Using an e23 hydrobooster is the method used by so many Europeans for decades when swapping an S50/52 engine. ;-)
          Here's another.
          massivebrakes.com
          • Staszek
            • 2533
            Here's another.
            Yea thats Andrew's car, he said he loved the hyroboost.
            • Pootis
              • 636
              Well I'll try to take detailed pics of my install I just picked up all of the parts yesterday.
              • Staszek
                • 2533
                Please do
                • Massive Lee
                  • Sep 2006
                  • 6782
                  Originally posted by Staszek
                  Please do
                  If you search the net, there are many hydro boost installs in e30s. With detailed installation.
                  massivebrakes.com
                  • flyboyx
                    • 8371
                    i just recently came up with a better idea. the Cardone hydroboost unit. it is very small and compact. the accumulator is already integral with the unit. you only need a pressure hose in, a pressure hose out, and a low pressure hose that goes to the reservoir. everything else is self contained.
                    best of all, this unit came on many domestic vehicles such as the diesel pickups(my own f350 for example) and the chevy astrovan of which there are many of these in junk yards.
                    the unit will need custom machined adapters on both ends but i think it is a much better solution than bmw.
                    Gigitty Gigitty!!!!
                    • flyboyx
                      • 8371
                      by the way, that unit looks like it was out of either an e24 or e28? if you are using a 24 valve engine, this setup is not going to work for you. it sticks out too far as is written in the text above. look for an 80's 7 series e23. see the pic massive lee posted above.
                      Gigitty Gigitty!!!!
                      • Massive Lee
                        • Sep 2006
                        • 6782
                        Indeed, the e23 hydrobooster is about 1" shorter in the engine bay, and 1" longer in the cockpit.
                        massivebrakes.com
                        • Pootis
                          • 636
                          It's out of an 80's 7 series so should be the right one...but ain't nobody got time for 24v swaps.
                          Edit: It's out of an e32 so it is the longer version but shouldn't be an issue for what I need it for.
                          • Massive Lee
                            • Sep 2006
                            • 6782
                            Can you fit the hydrobooster with that V8 swap?
                            massivebrakes.com
                            • Pootis
                              • 636
                              Looks like it's going to work I haven't done the full testfit yet. I tried a gm booster and that thing was way too big but this is half of the size of that monster so I'm thinking it's going to work. Motor wasn't even bolted down in this pic.
