Long story short. I had the SIR B90 tool to remove the rear wheel bearings, got new ones from FCP Groton seemed a little suspect, no traditional markings SKF/FAG. I installed them and the hub on top and 1 seems very loose and noisy the other is binding.
Any tips on installing the bearings I froze them and they did go in quite easy even the hub on the bearings went on relatively easy.
I didn’t want to chance it and ordered a new set known brand SKF.
I’m going to remove them again-dreading since I had to splice out the inner race since it stuck to the hub.
But again-any tips on pressing the bearings in, I want to rule out my technique and blame the bearings but definitely want to make sure this time around.
Also any tips on putting the half shaft/axle back on, I pressed it out with a 3 jaw puller.
thx.
thx.
