any way to take the brakes n shit from a 86 535i to a 84 318i
brake swap
for the front, you need to have custom brackets made. for the rear, tough luck.
in any case, no point. give it up.
if you want to upgrade, you need to direct energy into a more logical route. evaluate your desired end result and make a path.
for example, if you are planning on keeping the same engine in, then just refresh brake lines, good pads and rotors (if needed). you'd be surprised what this will do for you.
if autocross, various HPDE's and preparing for an engine transplant, find some better struts and trailing arms from 6-cyl e30s. from there, you will be able to expand further.
Originally posted by Alkasquawlik View PostYou have a 318i, you don't need bigger brakes.Brake harder. Go faster. No shit.
massivebrakes.com
you havent been too specific though.
doesnt matter if the brakes come from 3, 4, or 5 lug, just that the fronts could work if you made adapters. the rear, on the other hand requires you to replace the entire trailing arm because there is no way to mount calipers.
hit up the junk yard and find an eta or i and gank the TA's and front struts and hubs. you'll need the 2.93 diff from the eta and the half shafts too.
The answer is easy. No, you cannot swap the 535i brakes to the e30. Two totally different cars with totally different suspensions. You will obviously need more braking power with the M30 motor. You can swap the brakes/suspension from and e30 M3 (about $1800), from an e36 and.... damn, that subject was already covered, so many times.Brake harder. Go faster. No shit.
massivebrakes.com
Or go rear discs and Massive's Street kit up front.....Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Originally posted by z31maniac View PostOr go rear discs and Massive's Street kit up front.....
Basically, the OP will need to swap rear trailing arms from a 325, as well as differential and half shafts. The 318 has a small case diff and weaker halfshafts. That woud be the best time to weld camber adjusters on the trailing arms, then beadblast everythig and apply a fresh coat of paint.
LeeLast edited by Massive Lee; 08-04-2009, 05:48 AM.Brake harder. Go faster. No shit.
massivebrakes.com
You are correct. However, I wanted the OP to actually have to search for some info!Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
