seized ball joints?
  • awestun
    • Apr 2009
    • 196
    seized ball joints?
    So, I have been trying to get my ball joints off of my front struts for about 3 days now and I have had no luck. I've read my helms manual cover to cover and it hasn't helped me. I've been using a ball joint remover that looks like this:
    Should I get a different tool?
  • wolfgangstbd
    • 960
    if you tried a BFH id try a RBFH and some liquid wrench.
    if your trying to get just the strut balljoint off its alot easier when the steering is straight. for me at least i couldnt get em out till i moved the steering around
    • awestun
      • Apr 2009
      • 196
      yeah I tried turning the wheel but it didnt help any.
      • asubimmer
        • 6482
        you would have a lot better lock w/ one of these...
        • awestun
          • Apr 2009
          • 196
          I think I'm gonna get one of those tomorrow and try it.
          • E30_fiend
            • Apr 2006
            • 7348
            PB Blaster is your friend.
            Had the same problems with a friend of mine's e30 and I sprayed a good amoun of PB Blaster on it, tapped it with a hammer to help work it into the joint. I left it for abour 20-25 minutes and nailed it with a hammer. A good trick is to thread the nut on a few threads and hit the nut instead of hitting the joint itself. Unles you dont care.
            Try that out and report back.
            Taylor
            • SkinnyVT
              • Nov 2008
              • 391
              another thing is to not use a deadblow or any hammer with a soft face, it needs the shock of metal to metal contact to break it loose.
              '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
              • awestun
                • Apr 2009
                • 196
                yeah I have a claw hammer and a small sledge hammer that I've been using but it no worky. I'm so frustrated I want to set my car on fire.
                • asubimmer
                  • 6482
                  try the tool I posted and you'll be a lot happier. They are magic
                  • 5KWattson
                    • Apr 2009
                    • 809
                    lol i did the ball joints on my w201 i dropped the control arms off the car got a shit load of PB and a RBFH after hrs of fuckin around with a med size hammer, twenty mins later had both ball joint out and new ones back in...i really need a alignment now though :(
                    "God created turbo lag to give V8's a chance" Taylor D.
                    • awestun
                      • Apr 2009
                      • 196
                      Originally posted by asubimmer
                      I'm goin to sears tomorrow to get one of those.
