CABs in lollipop with vise?
  • paddyhart
    • Apr 2006
    • 179
    Who has done it? Last time, I had a shop do it but now have a vise that I think might be able to do the trick. Any lessons learned?
  • slo325i
    • 417
    Just lube it really well??
    Wasn't too hard at all. Mine popped right in.
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
    • SkinnyVT
      • Nov 2008
      • 391
      you could always use the freeze/heat trick...throw the bushing in the freezer and the lollipop in the oven for an hour and then pop them together.
      '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
      • DJB
        • Oct 2005
        • 195
        Use the freeze/heat approach. But have a small sledge handy.
        The first time I did this job we used a large vise, but it wasn't strong enough. We had to tighten the vise while hitting the face with a sledge.
        Ugly, but it worked.
        My friend now has a 20 ton press. With that and a pipe clamp to reinstall on the car, a CAB replacement is fast and easy.
        • Aptyp
          • 6584
          I used Dawn dish soap to put them in :)
          • deutschman
            • May 2008
            • 5958
            just lube it up with some laundry detergent. it works perfectly. thats what i did and it worked grate.
            • Red88
              • Nov 2008
              • 1161
              This. It took me less than 45 minutes from jacking the car up to putting it back on the ground.
              Have you made a purchase from www.blunttech.com recently?
              sigpic<< wrecked
              • tonytony
                Knee deep in poopie
                • Jan 2004
                • 3498
                ^^^^you guys use soap to lube up the cab and stuck it in the lollipop? Or did you lube up the cab then stuck it on the control arm? I dont think soap is going to be sufficient in lubing metal on metal, unless you're talking about the latter. I used my friends dads hydraulic press to press the actually cab into the lollipop. I just stacked on the new cab ontop of the worn out one and press the new one in while the old one came out.
                • FredK
                  • 14763
                  Yep, I used a 5" bench vise to press mine into the lollipops. If you put it in the freezer it'll ease the assembly process.
                  To actually lube it up and press it onto the control arm, I use turpentine, because it actually dries out.
