B90 Tool worth it?
  • alpinewhite318i
    • 134
    B90 Tool worth it?
    Has anyone used the B90 tool for the rear wheel bearing? Also does this tool have the attachment to pull the halfshaft into the hub?
  • FredK
    • 14762
    I've used it a few times. It does not have an attachment to pull the halfshaft into the hub, but the halfshaft should slip right in. Sometimes it takes a little coaxing, so you can place a piece of wood on the flange and tap it in with a hammer.
    It makes the operation easy to perform while the trailing arm is still on the car.
    • Julien
      • 7471
      i just use a slide hammer and some willpower to get them out
      Build Threads:
      • Gnarles
        • Dec 2008
        • 342
        I used the wheel bearing tool from harbor freight last month to do my wheel bearings and it only took a couple of hours to do both sides. Definitely worth the purchase.
        • kencopperwheat
          King of Kegstands
          • 14396
          I used a 10lb slide hammer and it still dragged the nut accross the threads on the shaft.
          Originally posted by Gruelius
          • Gooch
            • Dec 2006
            • 1674
            It's definitely worth it to rent it, check out the NJ BMWCCA toolbox and shoot Ken an email.
            '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
            '87 535i - Vacuum brake conversion [SOLD]
            '93 525iT - 5-speed swap - 320k and counting
            '09 328xi - 6-speed
