what bushings should i change
  • rede30
    • 4697
    like i said what bushings should i change when i do my suspension this christmas. i am not going to drop my rear subframe but other than that what should i change out.thanks
    Dustin
  • Charlie
    kid tested, administrator approved
    • 6686
    Everything you can access when you have the subframe pulled.
    Seriously, it's a pain in the ass, rivaled only by having to do it twice.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
    • CleanAzzE30z
      • Jan 2004
      • 11794
      perhaps some ///M3 control arm bushings and some GC rear shock tower mounts could be a start.
      • Charlie
        • 6686
        Oh, you said "not pulling the rear subframe"
        In that case, CAB's, that's about it.
        -Charlie
        FYYFF
        • Skafrog
          • 1732
          also, if you want to go the cheap bastard way, you can get e46 m3 convertible rear shock mounts. Either way, you would be well served to change the CAB's and the rear shock mounts, as they are probably worn out by now. If you can, get some nice solid CAB's with e30 m3 geometry.
          NASA MidSouth TT Director / GTS2 #018
          Mods: Coastal PS Fluid, 10w40 Oil
          Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
          • rede30
            • 4697
            thanks for the tips guys, should i change the front shock mounts and is there a bearing up there that should be changed? thanks again
            Dustin
            • ///M Powered
              • Jan 2004
              • 1109
              Originally posted by Skafrog
              also, if you want to go the cheap bastard way, you can get e46 m3 convertible rear shock mounts. .
              Or go even cheaper and use e30 cab rear mounts. :oops:
