polyurethane lube
  • T Verdier
    • Aug 2007
    • 2636
    polyurethane lube
    so we all know that polyurethane needs to be lubed or it gets really squeaky.
    my question is, should i use the lube they sent me or should i spring for some higher quality lube? i heard that some people use marine grade lubrication on there bushings. as my car is a DD it sees a whole winters worth of rain and im sure that marine grease will hold up better. anyone try this or think its a bad idea?
    P.S. IE sub frame, trailing arm, sway mounts all street grade poly.
  • Aptyp
    • 6584
    i use lithium grease, same one I use for brake calipers.
    • guibo09
      • Dec 2008
      • 834
      i used copper anti-seize.
      90 E30 325i
      • tonytony
        Knee deep in poopie
        • Jan 2004
        • 3498
        i used whatever came with the bushings which is probably copper grease. Had them in for a year and no squeek that i can detect.
          I've had good success using synthetic brake grease. It seems a bit more water resistant that the grease furnished with urethane bushings and lasts longer. But nothing I've tried lasts much more than a year.
          • StereoInstaller1
            GAS
            • 22679
            I made the mistake of using the grease that came with the bushings. Shit was quiet for like 3 weeks, maybe. Now I gotta pull my damn trailing arms out AGAIN because I was too lazy to go get the right shit...fuck that noise, man!
            Marine grease FTMFW.
            Gonna do zerk fittings in those TAs when I go slotted.
            Luke
            Closing SOON!
            Thanks for 10 years of fun!
            • Gnarles
              • Dec 2008
              • 342
              I also used anti-seize on my bushings. No squeeks after a year of use.
              • T Verdier
                • Aug 2007
                • 2636
                Luke
                Nice! Your the one I was told did that. Do you remember the brand?
                Zerk fittings? hmmm.
                • guibo09
                  • Dec 2008
                  • 834
                  i had greased my poly bushings with high quality synthetic lithium grease. then had issues installing, realised i did something wrong, couple of days later, pulled them out. i found that there was almost no grease on the close mating surfaces. what was left felt dry.
                  conclusion: unless there is some provision for grease to stay and flow (channels, slots, cross-hatch, etc), most, if not all gets pushed out with installation since the grease is to thick. oil would fit but leak away quick. thats why i used antiseize, it's thinner yet holds to surfaces very well. i think it will last longer.
                  90 E30 325i
                    • 34844
                    I used whatever came with my bushings from IE.. in 2003. Never heard a squeak.
                    now, the heim joints on my first set of adjustable swaybar links that went bad.. those squeaked like crazy!
                    • StereoInstaller1
                      GAS
                      • 22679
                      Yeah, back in the GM days I always did zerk fittings for control arm bushings, sway bar bushings, all of that.
                      As far as grease...NFC. I just got whatever marine grade grease they had at the boat shop.
                      Luke
                      Closing SOON!
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        what are zerk fittings?
                        • T Verdier
                          • Aug 2007
                          • 2636
                          a nipple that you can pump grease into.
                          are cars dont have them but my dads ford did.
                          • tonytony
                            Knee deep in poopie
                            • Jan 2004
                            • 3498
                            ahh those things, man that would be nice to have if and when my bushings start to squeek
