OK so I am running a Massive street kit that I pieced together (didnt buy from Lee complete) I am getting the calipers tommorow and want to get the brake system buttoned up. What brake fluid should I be using with this and how much do I need? 1 or 2 cans? Sorry for the Brake noob
Wiwood Dynapros, What fluid?
DOT 3 or 4 will work, DO NOT USE DOT 5!
1 quart/liter (I don't remember what the bottle sizes are) should be enough to flush your entire system. For my street cars I just use Valvoline synthetic if you can find it, for the track I use Motul. Pretty much any Dot 4 fluid will be adequate for street use.sigpic
'86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle -
I'd go with any DOT-4, and get a quart of it. Try not to spill too much fluid when disconnectig the hoses. If you could waste under a spoonfull or two per side, it will make bleeding a snap.
Don't forget to use teflon tape on the 1/8npt fittings at the inlet. And don't forget to post pictures either...Brake harder. Go faster. No shit.
massivebrakes.com
Bleed the top ones only. Inside first. Then outside ones. After the first bleed, it doesn't really matter.
Lee
PS There are bleeders at the bottom just because Wilwood wanted to make one caliper for both sides.Brake harder. Go faster. No shit.
massivebrakes.com
