Diff Fitting
  • Japandrew73
    • 2164
    Diff Fitting
    Is the Differential Fitting on the 318i, the same as fitting a 3.25lsd from an e28 onto a 325i subframe?
    Anybody have experience with this?
    For a better understanding of what I'm asking...
    I've currently got a 318i subframe and whatever the stock diff is it comes with.
    I'm going to swap in a 325i subframe and a 3.25lsd from an e28. Im talking about the distance from the driveshaft flange to the diff
  • e30s52
    • Oct 2007
    • 5235
    You need to swap the rear case cover and the two drive flanges.
    www.gutenparts.com
    • Holland
      • Nov 2008
      • 7212
      The subframe should be the same. I swapped a 188 case 3.73 out of a 325is in my early 318.
      Originally posted by DEV0 E30
      • Japandrew73
        • 2164
        Thanks guys!
          • 37832
          The ones off your original diff may not work though since it's a small case.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
