they showed how they bent a rod to hit the bolt from above
https://www.realoem.com/bmw/enUS/sho...diagId=33_0213
So how can you hit that down? Wouldn't it catch on things? \
Regardless, I have tried hitting from below to no avail. I also jacked the car up via this bolt but it just lifted the car! The bolt didn't budge...
Not sure which way to hit this bolt. From the top or the bottom???
edit: obviously figure it out (sort of) after posting... so it looks like you pound the bolt UP, then use the rod to pound the bushing DOWN.
edit2: after a while none of the above actually did the trick for me. for those interested I ended up putting a mini jack between the upper spring perch and lower spring perch (ish, but a bit up onto the arms) and it came out. I wouldn't recommend doing it that way but it's all that worked for me. I didn't take any pictures b/c it was pretty sketchy
